Hunt’s Point bridge height
Discussion in 'Questions From New Drivers' started by Scream'n Hauler, Mar 23, 2021.
  1. Scream'n Hauler
    Scream'n Hauler Light Load Member
    69
    57
    Jul 13, 2014
    My Trailer is 13’6”. How did I fit under a 12’10” bridge?
    Wasted Thyme Thanks this.
  3. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    New York law says bridges must be marked lower than actual clearance. I forget exactly how much lower.
  4. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    New York is famous for bridge heights.
    Tb0n3 Thanks this.
  5. Judge
    92,796
    Very carefully, tip toe.
    Scream'n Hauler and Snailexpress Thank this.
  6. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    Lol my gps spazzes out when I go to huntspoint. I myself never understood NYC clearance signs. Some say the clearance is marked for snow. Some say it’s marked at absolute lowest point and the curb takes a foot from the actual clearance. Some say they just remove a foot. Honestly I don’t know. I’ve seen bridges marked 11”6 that I passed and I’ve seen bridges marked 13”2 that a truck got stuck under it.
  7. Ffx95
    1,370
    2,635
    May 18, 2017
    Oh also quick tip. Make sure you take your turns wide enough that you don’t climb the curb cause a lot of these bridges have JUST barely enough clearance that climbing that curb will make you too tall and might end up rolling you over.
  8. wis bang
    wis bang Road Train Member
    3,468
    4,128
    Jan 12, 2011
    Levittown, PA
    Always fun on the BQE near the Brooklyn Bridge watching first timers hit the brakes only to realize they just watched 20 trucks go under the bridge.....
  9. JerzyG
    JerzyG Light Load Member
    93
    265
    May 23, 2020
    If I remember correctly, if it's a yellow clearance sign you have to add a foot to get the actual clearance height and if it's a white clearance sign then it's the actual height.
  10. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Leave it up to New York to institute a system like that. Here is an IDEA........MEASURE THE EFFING CLEARANCES AND SIGN THEM ACCORDINGLY!
    Vic Firth Thanks this.
