I did not know about refusing a pre-employment screening
Discussion in 'Questions From New Drivers' started by atlaslogger23, Oct 30, 2023.
  1. atlaslogger23
    atlaslogger23 Bobtail Member
    4
    Jun 27, 2023
    So how is it that my choice in deciding not to take a pre employment ua now makes it so i can not drive a commercial motor vehicle?? please tell me how much of a dumb #### i am....
    austinmike Thanks this.
  3. austinmike
    139,273
    Why did you not take the test ?
  4. TravR1
    TravR1 Road Train Member
    3,695
    9,783
    Nov 9, 2017
    TX
    You can't refuse those.
  5. SoulScream84
    3,458
    26,553
    Mar 21, 2020
    Failure to take a UA is viewed the same as failing one.
    https://www.fmcsa.dot.gov/regulatio...er's refusal to submit,a drug or alcohol test.
    Magoo1968 and austinmike Thank this.
  6. Ridgeline
    22,742
    123,693
    Details ...
  7. TripleSix
    133,520
    They had you set up to be tested and you decided not to show. Why is a good question, but now it’s irrelevant. If you want to use that CDL that you have had for 2 years, you will have to complete a SAP program. You really should have posted as soon as possible, anyone could have warned you of the importance. Too late now.
  8. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Well, at least you don’t have to worry about throwing on chains now that winter is almost here.
    “As King, you must find the good in ANY situation.”
    -Longshanks
    TripleSix, TravR1, bryan21384 and 3 others Thank this.
  9. tscottme
    tscottme Road Train Member
    This is the only industry I've worked in where so many people only ask the important questions AFTER they "jump off of the cliff". I recognize most drivers don't refuse drug tests and then ask if refusing one is a problem, but this is not an issue in more professional fields.
    TripleSix, Concorde, Bud A. and 4 others Thank this.
  10. wulfman75
    wulfman75 Road Train Member
    2,447
    3,495
    Jul 15, 2010
    Athens, GA
    refusal equals failed.
  11. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    This comment really makes me mad! Not angry, MAD AS (redacted) at all the (redacted) truck stop attorneys and so-called experts all over the trucking profession who don't know their rear end from the Indiana State Ditch. There is a MYTH out there that you can refuse a pre-employment UA and be OK. It's a myth because it is only partially correct. I am not going to do all the linking to parts 40 and 391 to back this up. If you enter a secure testing environment and refuse to take that UA you are considered to have a positive test. If XYZ carriers tell you to go to the ACE clinic to test and you don't go you are OK. If you are on the property of XYZ or any (secured) location during orientation and refuse to test most likely they will finish the chain of custody form on you and send it to the MRO (as refused to test) who WILL add your name to the Clearinghouse.
    Edit: I forgot this important point! The only thing you stand to lose doing a UA is something you dispose of several times a day anyway. If you are clean what is the harm in giving up some urine? If your urine is dirty or you suspect it might be you are most likely going to test positive later. I never really understood the mentality of refusing to test as I said all it will cost you is a urine sample. This is a subject where I once saw a Safety Person shrug and say "search me".
    lual, Bud A. and Eddiec Thank this.
