I got the shakes, man!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kamkor, Aug 14, 2016.
  1. Kamkor
    Kamkor Road Train Member
    3,324
    3,570
    Jan 18, 2012
    Wellington, TX
    So I have a 17 Cascadia, and I have a weird vibration issue. (I know, its Freightshaker....)
    Anyways, bobtail and highway speeds, pretty darn smooth (For bobtail at least).
    If I attach to a trailer, I get a noticable shake in the rear at highways speeds, starting around 60 and moving up to 70+.
    Happens with any trailer, same speeds. Empty and light trailers its the worst, as the trailer weight on the drives gets heavier the shake diminishes, but never ceases really, unless I'm on a slightly bumpy road. A smooth fresh highway and you'll still feel the shaking even at 34K.
    It feels like it originates in the rear passenger side, and if its a light trailer it slowly gets worse.
    Ride height is in spec, the tires on the right side were actually recently replaced due to road damage, but the issue was there before and after. Drive line has been balanced, bearings on all axles checked and good. Havent seen any odd wear on the tires either yet. Tires are Michelin Line One Energy D wide base super singles. Vibration feels like shaking about 10 times a second, so I think that would rule out driveline since thats more in time with a tire rotating. Also, the vibration doesent change at all when the truck does its E-Coast thing and shifts into "Neutral" while cruising. So I believe that rules out engine/driveline/transmission. Alignment has been performed. Truck is at 37K miles. Vibration does increase in frequency with speed.
    I'm wondering if maybe I have a bad rim that may be a little out of round causing the vibration but why wouldent I feel it when bobtail. My grandfather who use to work on big trucks thinks maybe it could be a bad shock causing it when I have weight applied. Visual on the shocks show none of them leaking or damage, but of course its factory shocks. Just trying to get an opinion on it before I start throwing money at the issue.
  3. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    I had a similar problem years ago on another truck I owned. I put the truck on jack stands and put in gear and took it up to 70 mph. Turned out one drive wheel wasn't concentric on the hub.
    Another thing you should do if you haven't already done so is check the driveline angles. If the angles are a bit borderline to start with, even with airbags a trailer can push down and that half degree out gives you driveline vibration. I've had that problem myself also.
    x1Heavy, Snailexpress and Heavyd Thank this.
  4. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Get yourself a spicer Anglemaster, max angles on UV is 3 degrees, loaded or unloaded.
  5. Heavyd
    Heavyd Road Train Member
    7,829
    6,279
    Feb 4, 2009
    Shakes, shimmies and vibrations. They all have a different feel to them and by what you feel can help pin point what it is. Vibrations are more from higher speed components like the engine, trans and driveshafts. Vibrations are more like a hum or buzz feel. Shakes and shimmies are more from slower moving components like tires and wheel assemblies. Since wheels spin about 3-4 times slower than the drive shaft, depending on your drive ratio, they tend to develop more of a shake. Coincidentally, highway speeds is what generates a resonance frequency in unbalanced or out of round tires/wheels to cause this shake. A tire or wheel shake frequency is slow enough that you can almost count the pulses. Generally, if you feel it in the seat or floor, it is a drive tire. If the steering wheel shimmies back and forth, it is a steer tire. In your situation, I think you have a drive tire out of round. Bobtailing allows the wheel to bounce and your suspension and shocks are able to dampen it. With a slight load, the extra weight forces the bouncing to be more pronounced, but with heavy loads the trailer is basically forcing those wheels to run smooth as the weight over powers and totally dampens the shake and this is why you only feel it with a light load.
    heyns57, x1Heavy, Oxbow and 6 others Thank this.
  6. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Out of balance,tire and or wheel.
  7. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    It sounds like you might have a mis-mounted rear tire? We had new steers put on where one was off enough to feel a front end shimmy, took the truck back and they remounted it and said the last guy didn't use enough lube when the tire was mounted, so when the bead was seated it was off set on the rim. It cured the shimmy for us.
    It makes sense a loaded trailer shakes less than an empty one, the weight or mass of the load is acting like a dampener.
    Keep us posted on what the problem was when you figure it out!
    x1Heavy Thanks this.
  8. Kamkor
    3,324
    3,570
    Jan 18, 2012
    Wellington, TX
    This. I can just about count the shake frequency. And it's not felt in the steering wheel.
  9. Kamkor
    3,324
    3,570
    Jan 18, 2012
    Wellington, TX
    The problem is finding places that will mess with super singles. I found one place in kingman as that will balance them, but they have to take the hood off their machine, making it run about 300 for all four.
  10. rollin coal
    rollin coal Road Train Member
    13,655
    28,094
    Mar 29, 2008
    TN
    Sometimes you do what you gotta do. I would get them balanced and see what happens. I was so picky about balanced wheels/tires that I started mounting my own and putting dynamic balance media in them because it's expensive paying someone to do it. I dread doing it, I hate it actually, and it's hard work when you don't do it every day. But it only costs me some sweat and time. I wonder if maybe you have a brake drum out of balance? I dunno just throwing the easy stuff out there. I had issues like this years ago with my truck and I know how it sucks to drive one like that but eventually I got it riding smooth as silk.
