I think I know why B-doubles often have tri axles.
Discussion in 'Questions From New Drivers' started by TomCougar, Oct 17, 2019.
  1. TomCougar
    TomCougar Light Load Member
    180
    146
    Sep 4, 2019
    Lawton, OK
    Those three tandem axles tend to want to make the trailers track straight while backing and not easily veer left or right.
    Am I correct?
    Here is a yootoob demo of B-double backing:
    blairandgretchen Thanks this.
  3. Cat sdp
    Cat sdp . .
    21,318
    76,328
    Apr 8, 2012
    Orion's Belt
    Weight might have more to do with it....
    Backing is a little easier because there is one less pivot point that a doubles set up with dolly.......
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Lmao. What Cat said, it is all about weight. lol
  5. blairandgretchen
    13,978
    76,874
    Dec 9, 2011
    South west Missouri
    Them B-doubles got your interest, huh? :)
    Bean Jr. and D.Tibbitt Thank this.
  6. AModelCat
    164,926
    Funny thing is, if you look at the weight laws (here in the part of Canada I'm in anyways) the load per axle actually goes down with each axle added to a group. Single, non-steer axle is 9,100 kg, tandem axle group is 17,000 kg and a tridem group is typically good for 24,000 kg. With that in mind, I think the weight is irrelevent. Its the lack of converter dolly, which in essence is really just a super short trailer. The more pivot points you add, the more the combination wants to wag.
    Farmerbob1 and D.Tibbitt Thank this.
  7. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It is probably worse than that here, we are allowed 38,000 on a tandem, and just 42 on a tridem, between that and the bridge length, a b-train that is Canada legal on weight can not come across the border in to Alaska.
    There are a few, not many side dumps here set up like b trains, but they have 4 axle leads and both trailers are full length. It is rare to see a set of them anymore, the one company that ran them went out several years ago.
    D.Tibbitt Thanks this.
  8. TomCougar
    180
    146
    Sep 4, 2019
    Lawton, OK
    Yes, they are so weird, they're actually fascinating. I discovered them by accident by playing a vehicle action game on my PC. As a truck driver, I would only want to pull a single trailer, no exceptions. But it's so much fun just to watch that long alligator-lizard-like Campbell's soup B truck slither around tight corners, swinging super wide, creeping at about 8 scale MPH, on my virtual model railroad layout. Yes, they are quite different from your everyday tractor pulling a single Walmart box, indeed.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I have Super-B train (B-Double) hopper bottoms.
    I’ve even backed them into a mechanics bay without room to pull completely straight ahead. You get use to it.
    Fun fact. Sometimes when I call a farmer that I’m going to load at, the first thing they ask is “can you back up ?”. Some of the older farm yards are pretty tight.
  10. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    First set of Super B's I ever pulled, taken in 1978 at the Moosomin SK scale.
    Not often I had to split them, could back them nearly anywhere you could put a straight trailer, but trucks were a bit shorter back then.
    The GCVW at the time was 135,000 lbs in Ontario, 110,000 lbs in western Canada which was later raised, also why the lead axle is raised.
