Iceless Cooler and Coffee Maker - 12V
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by tderrick, Apr 20, 2015.
  1. tderrick
    tderrick Light Load Member
    106
    22
    Jul 26, 2014
    Nashville, TN
    I'm in the market for an iceless cooler and a small wattage coffee maker to save some $$$ clams on the road.
    Any recommendations ? ... or better yet, makers / models to avoid?
    thanks in advance for any help....
    ps ... I have a very small inverter, so I need to keep things at the 12V level for now...
    grazie
  3. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    tderrick Thanks this.
  4. AL_Dutch
    AL_Dutch Bobtail Member
    26
    20
    Jun 30, 2013
    I have the igloo cooler, it works great.
    Have not find a 12v coffee maker I liked.
    Tried a few, but all are way to slow.
    I have a 1000w inverter. 110 coffee maker and microwave.
  5. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    I've used an Igloo coolor(40qt) for years and the only problem is that the plug can get so hot it melts. I hard wired it into the fusebox and no more problems. I mostly local now so I now only have a small one, 12qt I think, still Igloo and no plug problems. Take it home every night and plug it in a 12v power supply to keep my stuff cold. As for 12v coffee pots. I bought one years ago and by the time it got done filling that litlle pot I didn't want coffee anymore. Had to have taken at least 45 minutes. maybe they are better now.
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    12 volts is time consuming. Takes me half hour to heat up water for noodles.
  7. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Not cheap but the Dometic CoolFreeze 12v fridge/freezers are awesome. They can operate as a fridge or freezer if you want. When I was a company driver for SNI, I used it for a fridge, and since the KW I bought has a fridge built in, now I use it as a freezer to keep frozen meals in. Much more efficient than the thermoelectric coolers, and will keep stuff cold even in a hot cab where the cheaper coolers won't. They have a small compressor just like the real thing and use very little energy. SNI was pretty bad about their no-idling policy so idling to charge the batteries was pretty much out of the picture. This thing never gave me any issues, I could even leave it turned on when I was at home for 5 days and it wouldn't set off the low-voltage cutoff.
    I have this smaller model:
    http://www.adventurerv.net/dometic-coolfreeze-portable-refrigerator-freezer-cf25-cf025dc-p-1227.html
    As for a coffee maker, you may not be able to use a 120v model unless you have a larger inverter. When you say you have a "very small" inverter, how small are we talking?
  8. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    Do yourself a favor and get a French press. Less than $15 at Wally. Figure out a way to make hot water. I used a camp stove before I got with an apu outfit. Be careful of the iceless cooler. It'll freeze stuff close to the cooling element.
    dannythetrucker Thanks this.
  9. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
    That cooler sounds great... I'll check it out...
    as for the inverter, I just picked up a 150 watter to charge my PC to get started. I've only been driving
    for a couple of months, so I wanted to look around at what larger units to get.
  10. tderrick
    106
    22
    Jul 26, 2014
    Nashville, TN
    That French Press sounds awesome...... now, for the hot water....
  11. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    I bought a Coleman cooler at Walmart with the 2 year insurance plan for $8.00. It worked well for a year and then the fan burned up. I hauled it back to Walmart for exchange and was told that was a 3rd party insurance company. They had me send in the receipt but due to shipping costs did not want the cooler back. I was issued a Walmart gift certificate for the cost of my cooler. I bought a new one and now have 2. The fans are easy to replace computer case fans and only cost $5-15. After I cash in my second insurance plan I will have 2 Coleman coolers for 16$. When one goes down I swap them out and fix the other one at home. Yeah I am a cheap SOB.
    RoadCall Thanks this.
