Is a flat airbag a dot violation??
Discussion in 'Questions From New Drivers' started by asphaltcowboy4x4, Feb 16, 2019.
  1. asphaltcowboy4x4
    asphaltcowboy4x4 Medium Load Member
    682
    479
    Dec 22, 2018
    i had an airbag on the trailer blowout the mechanic if bypassed it but is this still a dot violation?? Or can I wait awhile to have it fixed?
    Rideandrepair Thanks this.
  3. nikmirbre
    nikmirbre Road Train Member
    5,590
    10,358
    Jul 27, 2011
    High Point NC
    Yes it’s a violation.... and I bypassed it. I received a violation in Georgia.
    About 10 years ago.....
  4. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Yes that is part of the suspension, also any major air leaks will put you out of service.
    PE_T and Rideandrepair Thank this.
  5. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Get it fixed.
    Grubby, PE_T and Rideandrepair Thank this.
  6. aramil248
    aramil248 Road Train Member
    1,410
    1,430
    Jan 16, 2017
    Maine
    That's like asking is having a inner drive tire flat is ok
    Grubby Thanks this.
  7. Espressolane
    18,690
    117,154
    Do you have pictures?
    Only on one side? If it is bad, get it replaced.
    Not as expensive as having a call out at a scale to fix it.
  8. bryan21384
    bryan21384 Road Train Member
    15,743
    34,313
    Sep 18, 2009
    Memphis, TN
    Why is that even a question? You better get that fixed....the DOT will put you out of service for that
    dibstr Thanks this.
  9. themistknight
    themistknight Bobtail Member
    8
    Jan 29, 2014
    Johnson City, New York
    I have came across many trailers with bad or low air bags. I came onto some where the air bags looked like they was low or unable to fill. But the design of those bags and age of the trailer made it look like they was not working.
    Look and listen to a leak and if there is one fix it. I knew one person getting hundreds to thousands of dollars in fines and points on his record.
  10. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    A driver should NEVER place a CMV on the road knowing there is a defect anywhere on it. I admit I have driven my truck for a ways to get to a service point. But if you are in such a place where you are going to cross a place with a bad reputation for busting drivers (like Banning Calif) DO NOT DRIVE! A violation for a busted airbag is not going to get you sent to the Florance supermax in Colorado. However, an OOS can be a pain in the butt!
    brian991219 Thanks this.
