ISX 550
Discussion in 'Kenworth Forum' started by Perchie15, Nov 9, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    253
    75
    Aug 16, 2021
    I am having issues with a ISX Cummins it keeps saying low coolant but it’s topped up, I bypassed the prongs coming off the sensor only 2 prongs there but still showing the light. It’s one of them hard plastic reservoirs. Even when I disconnect the plug
    From the sensor still says low coolant!! Multi meter is saying .5k ohms off the sensor
  3. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    Try putting a magnet on the end of a
    The sensor for a minute.
    It's actually usually the float inside the tank that goes bad.
    The fix is to replace the whole tank
  4. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    The float is stuck or sunk. Replace the entire surge tank, comes with a new sensor.
    Make sure the wiring pins to the sensor are good and replace them if needed. When you wedge a wire or paperclip in the pins they get spread and wont make good contact anymore.
    Judge Thanks this.
  5. Perchie15
    253
    75
    Aug 16, 2021
    K thanks guys I heard of that issue before but was hoping was something else. Magnet I’ll try and see what it will give me. If magnet doesn’t change anything on the sensor then still a tank problem?
  6. Perchie15
    253
    75
    Aug 16, 2021
    Is the magnet suppose to stick? Cuz it’s not use my light magnet lol and I guess it’s .5kohms. Not 5.0 my bad
  7. Judge
    92,737
    Yep agree, gotta change the entire tank.
    Mine did that last year when it started to get colder outside.
    Got mine through parts geek.com was a lot cheaper than KW.
  8. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
    You can pull tge sensor out and tape a magnet to the end to make the digging stop
