JB Weld Saved me 3000$
Discussion in 'Peterbilt Forum' started by calvinbabb, Apr 3, 2022.
  1. calvinbabb
    calvinbabb Light Load Member
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    2015 Peterbilt 579. Heat stopped working. 60$ for the part over 3000$ for labor. I took the actuator out and yes, the inside was stripped. Can’t get a dealer willing to do the job for 6-8 weeks so had to do something just to have defrost.
    Cleaned out the door socket of any plastic shavings. Made a 3/8” ball of jb weld water stick cause it has a work time of 25 minutes. Put The ball in the socket. I sprayed silicone spray on the actuator gear and inserted it in position. Removed the actuator to insure no jb weld got into the pivot point. Reinstalled the actuator and bolted into place. They say 1 hr cure time. I gave it 5 hrs. Started the truck and let it warm up and plugged the actuator in and turned on the system. My hvac is now working the way it did on day 1. Could’ve cost +|- 3080$. It actually cost 6.75$ and my time.
    baha, Tropsnart, jsnell and 12 others Thank this.
  3. Judge
    92,071
    That’s ok, we’ll take the rest of the money you would have spent, and put it away.
    That way if you need it again, you can call on a leap year to get your funds, from 1430-1500 on Feb 29th.
    Hold times count against your 30 minute clock.
    Thank you for your cooperation and understanding.
  4. nikmirbre
    nikmirbre Road Train Member
    5,588
    10,347
    Jul 27, 2011
    High Point NC
    I like reading about ingenuity! I mean I know thats what JB is for but, how many of us would've thought to do that? I know I wouldn't of!
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    You just wrote your thesis for a Degree in Roadside Wrenchbending. That right there is the difference between a mechanic and a parts changer. And you didn’t even need a computer to tell you what part needed attention. From this day forth, you no longer have to take any #### from the kids at the dealers with the surgical gloves, headphones and attitude.
