Kw fuel tank bracket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by btackett, Oct 17, 2023.
  1. btackett
    btackett Bobtail Member
    18
    Jan 21, 2012
    salem mo
    Will 2 brackets work on 150 gal tanks?
    W923 Thanks this.
  3. W923
    W923 Road Train Member
    1,420
    4,400
    Feb 28, 2022
    Yep but 3 would be considerably better
  4. wore out
    wore out Numbered Classic
    17,349
    215,462
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Being honest I can’t remember a KW set up off top my head. And they may be completely different from a Pete. I know mine came with 150’s and 2 single straps per side. They are 4” wide though. Smaller diameter and longer barrel may come into play there I guess
    blairandgretchen and W923 Thank this.
  5. blairandgretchen
    13,952
    76,734
    Dec 9, 2011
    South west Missouri
    The 2 150 gallon tanks on the 379 are factory, but both front straps have cracked and broken in the last 5 years - keep in mind it’s a 1995 truck.
    Pete relies on support from top only, as I recall - KW support from bottom?
    W923 Thanks this.
  6. wore out
    17,349
    215,462
    Jun 5, 2013
    I did see the 3 strap set up on a KW today. Something tells me @W923 is right and the 3 strap is the proper for their 150’s
    blairandgretchen Thanks this.
  7. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    My KW has 150 gal tank and 2 straps. they are 4 or maybe 6 inch wide straps. Kw is a little different than pete on tank support. while the KW bracket doesn't go under the tank it goes a lot closer than a pete.
    W923, wore out and blairandgretchen Thank this.
  8. W923
    1,420
    4,400
    Feb 28, 2022
    From what I’ve seen most older kws support the tanks underneath with the bracket and then hold them in with the strap. Only ever seen 2 straps on 100 ish gallon tanks…bigger tanks generally have 3 but some only have 2 wide ones. The newer trucks seem to have more of the over the top bracket like pete and then straps holding the tank up. I believe I’ve seen both 2 and 3 strap versions but don’t claim to know all of the possible setups or if what I’ve seen is exactly factory. I personally would want 3 straps on a 150 especially with the condition of today’s roads.
