Leaking coolant.
Discussion in 'Volvo Forum' started by Snailexpress, May 1, 2015.
  1. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Please help me identify what it is leaking.
    Volvo 2009 whit ISX
    Leaking something what is attached inside the frame on passenger side. Four hoses connected, two connected to the pipes from the rear of the engine block and two to cooling system. Right now is dark couldn't see anything good what is leaking. Hope it's a rubber.
    Can I bypass this thing??
  3. Dna Mach
    Dna Mach Road Train Member
    3,305
    3,165
    Aug 8, 2008
    Texas
    Any coolant leak you can visibly locate is a good thing. On an ISX you are going to eventually start losing about a gallon every 1000 or so miles with no visible leak. That will be your EGR valve and it's not a quick or cheap job.
  4. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Can be a cold weep. Only leaks after everything cools down so you never see it
  5. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    Is it where the coolant filter goes? If it is you can't bypass it that whole part where the coolant filter goes cost me 300
  6. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Hi, some truck have a power steering heat exchanger (cooler) at the place you describe ?
    Ben
    Snailexpress Thanks this.
  7. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sounds like what Ben is saying, power steering cooler.
    Mine is located on drivers side but mine has a Volvo motor.
  8. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Thank you all guys for help. Yes it was a power steering heater. One of the rubber hose to connect heater core and pipe from the rear of the engine.
    Bad thing it's happen in rural south Illinois area at night. Next day was driving really slow to the nearest Walmart. Got big enough container to drain coolant and 3/4 inch diameter rubber hose from O"Raily auto parts.
    To drain coolant from radiator just use 1/2" garden hose, drive phillips srewdriver inside along the hose in a couple inches from the end. Then slide hose over the radiator drain nipple and push valve with screwdriver. Don't forget to put other end of the hose into container.
    Real problem was to fill system with coolant after repair. Total coolant loss was about 5 gallons and no final charge red coolant available around. I put some final charge but pink in color. Have no idea about can it be mixed or no
  9. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    The rules of the thump for the coolant mix is 10 % if you go above this the long life coolant will loss his (function) and act like std coolant. (That's what manufacturer told us about that?)
  10. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
  11. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    There is a little mistake by Snailexpress he type the wrong word, , ,i think
    The correct sentence is power steering heat exchanger (cooler) mean (oil to water exchanger).
    Ben
