Leasing from Landstar
Discussion in 'Lease Purchase Trucking Forum' started by rluky13, Nov 30, 2025.
  1. rluky13
    rluky13 Light Load Member
    102
    228
    May 3, 2025
    LV,Nv/Brunswick, Ga
    I have been watching YouTube and I have been seeing the light and dark about leasing from Landstar. I know at this time leasing is not the best thing to do but watching YouTube videos has me confused if leasing from Landstar is good or bad. So help me with all this.
    blairandgretchen Thanks this.
  3. nikmirbre
    nikmirbre Road Train Member
    5,590
    10,358
    Jul 27, 2011
    High Point NC
    Landstar doesn’t lease any equipment….
    Oxbow, blairandgretchen and tscottme Thank this.
  4. rluky13
    102
    228
    May 3, 2025
    LV,Nv/Brunswick, Ga
    OK, no leasing but let's say once your on with a truck how do they treat you as an owner/operator.
  5. blairandgretchen
    13,951
    76,726
    Dec 9, 2011
    South west Missouri
    Pretty badly. Schneider is a better choice.
    @Dave_in_AZ can answer questions.
  6. rluky13
    102
    228
    May 3, 2025
    LV,Nv/Brunswick, Ga
    Thank you. I am just trying to look at all the options out there.
  7. dosgatos
    dosgatos Medium Load Member
    607
    1,311
    Sep 18, 2012
    You don't lease a truck from Landstar. You lease your truck to Landstar.
    When people say leasing is not the best thing to do, they are talking about leasing a truck from a company.
  8. dosgatos
    607
    1,311
    Sep 18, 2012
    If you're a grown up, they treat you like a grown up. If you're out of compliance on something, they'll let you know.
    Consider it benign neglect. After orientation, you wander the wilderness and either figure it out or fail. Many fail.
    rluky13 Thanks this.
  9. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,232
    Sep 27, 2015
    I have been with Landstar two years now. I can tell you this, I hated it the first 3 months I was with Landstar. I think it was just a matter of learning the system though, a process that everyone seems to go through when they come here. Sure, you think you will make tons of money and in some cases you might. But not every week will be the same unless you have agents you work with consistently every week running the same freight and lanes.
    As far as freedom, in my experience as an owner operator, Landstar remains unmatched. I don't have anybody telling me when I can or cannot go home, I stay home as long as I want, I haul what I want, when I want, etc. You are required to have hazmat to come on to Landstar, but you do not have to haul hazmat. Landstar will claim you have to give the trailer up if you will be home longer than ten days, but I have been down for two weeks with the trailer at home while my truck was in the shop and Landstar never said a word.
    One really bad thing about Landstar is the shape of the trailers. And it truly isn't just Landstar's fault, either. Landstar can't repair what nobody tells them about and there are a LOT of trailers that knuckleheads will drop at drop/hook shippers and receivers with issues they won't mention to anybody. Could be as simple as a light being out, could be as bad as brakes hanging off the drums, blown tires, etc. Landstar will repair the issues, if you let them know about it but many people do not do that and leave it on the driver who has to use the trailer next to do it. That goes for the 120-day DOT inspections also. Landstar does require 120-day DOT on trailers and trucks. I have received a couple of little shirt pins (that I will never wear) for having all clean inspections and such, mostly from making sure I get the 120-day inspections done on the trailers I do pull and getting safety issues repaired. One agent I work with in particular every time I pick up a trailer from his shipper, 90% of the time, it needs the inspection and/or has some sort of issue. I have seen other Landstar drivers go in, drop and hook inside of 5 minutes leaving out knowing they didn't check anything at all.
    Overall, I think it is just about what it would be anywhere else, it is good and bad at times. But when it comes to the freedom and everything else, I can't imagine going anywhere else. Or at least not in the near future anyway.
  10. rluky13
    102
    228
    May 3, 2025
    LV,Nv/Brunswick, Ga
    Thank you for the insight.
    Stringb8n Thanks this.
  11. blairandgretchen
    13,951
    76,726
    Dec 9, 2011
    South west Missouri
    I was actually just pulling your leg - the other responses were accurate. I’ve been there 11 years now. It has its quirks, but if you’re in a solid financial position, and a good operator - it’s a good place to make a good living without going ‘full owner operator/own authority “.
