Leverage
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Lite bug, Feb 18, 2023.
  1. Lite bug
    Lite bug Road Train Member
    1,412
    34,861
    May 3, 2014
    Columbus Ohio
    I have had tennis elbow for about three months and it’s not getting any better. What could I do to make unhooking the loaded gooseneck trailer easier?
  3. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Does your landing gear have a two-speed jack?
    Also, you could install an electric over hydraulic kit, so you can raise it with a button.
    Lite bug Thanks this.
  4. Steamnsteel
    Steamnsteel Bobtail Member
    39
    30
    Jan 19, 2016
    3 months and not getting better. I went to the see ortho about my tennis elbow and here is the solution given instead of surgery. I have tendons that are severely torn. Wear the brace very tight, even while sleeping. It took 2 years for me left arm to get better and now I have torn the right side. The Ortho Doc told me that it is due to overuse and surgery has a lengthy recovery. Try the brace shown, I have tried them all and this one seems to work best, Doc told me to keep it very tight and place the cushioning pad on top of the sore area. Just a thought to maybe help you along and still keep functioning, yours might be different but it is worth a try. Mueller is the brand in the following pic and can be found at most big box pharmacies. I am not a doctor but I have slept at the Holiday Inn.
  5. Lite bug
    1,412
    34,861
    May 3, 2014
    Columbus Ohio
    Thanks, I have one it helps a lot. I have had this before and it went away with the lock down and closed gym. I work out as often as I can. It is caused by over use and a muscle imbalance. I do not do the right exercises when it is not hurting and mainly my own fault.
  6. ducnut
    ducnut Road Train Member
    2,610
    7,868
    Dec 31, 2010
    SPI
    Don’t be this guy and think you can work through it or it’ll take care of itself. Permanent damage and constant pain, now.
    Left.
    Right.
  7. Judge
    90,750
  8. ducnut
    2,610
    7,868
    Dec 31, 2010
    SPI
    Food service delivery, running ramps. ;)
  9. DUNE-T
    DUNE-T Road Train Member
    7,028
    17,103
    May 10, 2015
    Detroit, MI
