Load securment is important
Discussion in 'Flatbed Trucking Forum' started by Old Man, Jan 8, 2016.
  1. Truckers Report Jobs
  2. passingthru69
    True, but I see more and more guys trying too thinking they will never move, I'm good
    RGN, tsavory and Al. Roper Thank this.
  3. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    Just like the drivers i seen today one had pallets of baged something one strap per row. I always put two on the front and to on the rear rows. But whay was worse was a daycab with about 40' of the deck used up with sheets of metal and only 3 straps.
    passingthru69 Thanks this.
  4. blairandgretchen
    13,977
    76,862
    Dec 9, 2011
    South west Missouri
    From intuition, seems you may have seen this one first hand - ?
  5. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    I didn't see it but I see a lot of Kubota tractors out of GA with straps only, my thought is if your in business and can't afford the right tools then get out before you hurt someone.
  6. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    At least they have straps.
    Around here locally I see kubotas and skid steers every day with no straps or chains on them.
    "They are heavy they won't move" or "the bucket is down" or "the rear ramp gate is closed"
    Amazing these clowns haven't killed anyone yet.
  7. MACK E-6
    50,095
    238,994
    Last I heard, unsecured load tickets aren't cheap.
    tsavory Thanks this.
  8. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    [QUOTE
    You can't secure tractors with straps.[/QUOTE]
    Ok, I'll ask a stupid question....
    Why can't you secure a tractor with straps? Assuming you tie down four corners, or run an x, etc. And assuming the WLL of the straps is high enough. What is different for straps vs chains?
    I'm personally against using straps on heavy things, I usually will use at minimum 4 chains to tie down the equipment, and use straps for secondary items, the bucket, mower deck, hoods, doors, etc. But I've been told before I go overkill on securement.
    Just asking to gain the knowledge. Thanks
  9. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,128
    Jun 3, 2015
    overkill on load securement sounds better than being road killed.
    Dominick253, tsavory and RustyBolt Thank this.
  10. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    Short answer, you can do as you suggest.
    You could also hunt and kill a bear with a knife. An ounce of intelligence will tell you It's not the correct tool for the job.
    If a driver wants to be lazy, then my only advise is, "You'd better watch out, them ba$ta@rds have big sharp claws!"
    Kinda like morons who haul stacked trailers with straps instead of cross chaining.
    Yes I can say that with prejudice.
    Legal speak for deliberately insulting.
    Why you ask?
    I haul trailers, all the darn time. Every time I unload, I stack up at least my jeep and most of the time my booster as well. That's 2 trailers stacked for approx 45% of my miles driven. I haul trailers around for about 40,000miles a year. With that much experience, I am beyond comfortable telling anyone that uses straps, they are a moron. Trailers can move, trust me, I know.
    If you don't plan to use the correct tools to do the job, you can't complain when you get a few claw marks.
    Straps have a stretch factor and are for loads that flex & twist. Chains don't have a stretch factor (relatively speaking) and are for keeping object from flexing or shifting.
    Man up, decks aren't for sissy's.
