Locked carrier x4 7300 controls
Discussion in 'Refrigerated Trucking Forum' started by Samuelh, Nov 9, 2018.
  1. Samuelh
    Samuelh Bobtail Member
    36
    39
    Jun 23, 2018
    The mode controls are locked in cycle. I need it in constant mode. Found the operators manual on line but doesn't address how to unlock it. Ant ideas?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    The 4 buttons along the bottom. 2 steps. Push button 1 and 4 at the same time and release at same time then push the =. It will go to advanced mode (it will give a pop up saying advanced mode). Push menu. Where there used to be a blank space on button 3 there is now a Functions button. You can change lots of things in here. Don't forget to change it back to idiot mode by doing the same 1 and 4 button then = again.
    Beyond that... I don't know. May be more programming that requires computer be hooked up to it.
    bzinger and Samuelh Thank this.
  4. Samuelh
    36
    39
    Jun 23, 2018
    No option in those menus to unlock the run mode. But defiantly good to know stuff. Thanks
  5. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Who's trailer is it?
    Some companies lock certain functions at certain temperatures so if it's yours you'll have to have it reprogrammed probably.
    If it's a company trailer call the company.
    KB3MMX Thanks this.
