Log Book updating question.
Discussion in 'Trucking Industry Regulations' started by 82ndCowboy, Jan 15, 2011.
  1. 82ndCowboy
    82ndCowboy Light Load Member
    91
    39
    Nov 9, 2008
    Osteen, FL
    I've been looking on the FMCSA's website and have yet to find the answer to this question. Maybe I missed it in the cluster#$## of regs I've been going through.
    But is there a reg that states how often you have to update your log book throughout the day?
    When you get a roadside inspection or get called into the coop. How far back can your log book be without any updates?
    Another question.
    Anyone know where to get a Hard copy book of all the regs?
  3. jezter5677
    jezter5677 Light Load Member
    145
    108
    Jun 11, 2009
    It should be up to your last change of duty status
  4. Alleycat
    Alleycat Light Load Member
    56
    12
    Nov 8, 2010
    Lafayette, La.
    What he said.
  5. Allow Me.
    10,766
    12,579
    May 28, 2009
    Rancho Mirage, Ca.
    Officially, it's your last change of duty status, however, in Ca. I've heard of drivers getting hassled if there's been no entry for over 4 hours, regardless. It wouldn't be wise to drive 11 hours straight (on your log) without some kind of break showing.
  6. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    eventho since 9/11 you can drive 11 hours strait its not healthy get out and check your tires and load every 3-4 hours and note it on the log you will get less hassel from dot this way
    panhandlepat, Everett and scottied67 Thank this.
  7. 82ndCowboy
    91
    39
    Nov 9, 2008
    Osteen, FL
    Thanks guys.
    I normally do it every time I stop. My Dad was telling me it has to be updated to the last 2 hours.
    He's always buggin me... did you do your log book...did you do your log book...did you do your log book...
    Sometimes I want to smack him with it.
    I finally found the HOS guidelines where it says must be updated to your last change of duty.
    I printed it out and I'm going to tape it to the dash in front of him.
    scottied67 Thanks this.
  8. walstib
    walstib Darkstar
    If he's sitting there next to you doing nothing, tell him to do it for you, you're busy driving!! :biggrin_25525:
    I am medicineman Thanks this.
  9. 82ndCowboy
    91
    39
    Nov 9, 2008
    Osteen, FL
    That would be a violation. You, the driver are supposed to fill out your RODS.
    Besides he's to busy telling me how to drive. :biggrin_25516:
  10. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    What about those Brake Check areas? One in Park City Utah on I-80 and before you hit the downhill on Donner? I was told you have to pull over and log a brake check 5 minutes, but I see trucks fly right by the brake check pullout like it isn't even there.
  11. B.A.D.
    B.A.D. Light Load Member
    91
    58
    Nov 5, 2010
    Pac NW
    Roger that. WA State driver's guide says that loads should be checked every 3 hrs or 150 miles. "Should", not "must", but if something happened that caused a driver to be stopped and there wasn't a VI on the log in the last 6+ hours, that'd be bad, right?
    Also, I'd be interested in getting a hard copy of the current FMCSA book as well.
