Low coolant warning bypass.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigstank, Jul 13, 2017.
  1. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    Hey guys I got a kenworth t660 with that push in coolant sensor. It's new, the plug is new and the float in the coolant tank works. But I keep getting a ding ding ding warning light and I'm fed up with this. Is there a way to bypass the wires by jumping it someway. Can't use a paper clip or tie the wires together. I did see someome say I need a 5v to a 1v resistor jumper when i Google searched. anyone know where I can get one or how to make one myself. Thanks
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Add fluids. Until sensor is happy again. PResto no more warnings.
    How hard is it to find enough fluids to make your truck happy again?
  4. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Coolant level is full. Matter of fact I over filled it just to be sure. It's been doing this on and off for 2 months and I'm done with. I appreciate your reply but im not a swift driver lmao!
    magoo68 and cnsper Thank this.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    you can just go to dealer and have them take out the engine protection for coolant sensor, or you can find where the wires are broke a tug test goes a long way, if you have cummins those #### wires are notorious for rusting out inside once you pull them a little bit they will give out right away.
    bigstank Thanks this.
  6. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Be on the lookout for bad grounds, especially if it does it on a regular cycle. Electrolysis can cause false low coolant alarms.
  7. Vargas7138
    Vargas7138 Bobtail Member
    Same problem, low-level warning, stop engine alarm, etc. Coolant level full, temps great. Took to local mechanic and he charged me $700 to replace(?). He told me the sensor was $300, the broke it off in me for another $300+ for labor?? Does this sound right? I'm seeing the entire tank (with sensor) online for $200.
  8. bigstank
    87
    19
    Mar 4, 2013
    missouri
  9. bigstank
    87
    19
    Mar 4, 2013
    missouri
    Sounds like he got ya for $$$. The coolant sensor is around $150.00 @ kenworth. And I got a new coolant tank for $300. I replaced myself and it worked and stopped the issue. The coolant tank comes with a new sensor already installed. These new tanks have some kind of float built inside and they break after a few years
    maconhadalata and Vargas7138 Thank this.
