low profile winches
Discussion in 'Flatbed Trucking Forum' started by ford06, Jul 2, 2017.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    can you run a low profile winch above a tire or will it still rub
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Deflate the bags and measure.
    cke and Ruthless Thank this.
  4. Ruthless
    Ruthless Road Train Member
    9,192
    91,291
    Aug 28, 2010
    The City.
    Depends on the clearance
    peterbilt_2005, cke and snowman_w900 Thank this.
  5. blairandgretchen
    13,971
    76,826
    Dec 9, 2011
    South west Missouri
    Porta-winches ?
    cke Thanks this.
  6. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,827
    Dec 7, 2015
    OK
    I can run them over my front axle but not the rear
    I pulled a trailer for awhile that standard winches would clear
  7. All depends on tire size and clearance from rubber to winch.
    My 24.5's. Rub against my winches due to tire and space. So I never run them by the tires.
  8. Zeviander
    Zeviander Road Train Member
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Fixed are better. Less flexibility, but less hassle. I wouldn't run a winch over a tire regardless of clearance mind you.
  9. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    I dunno I always prefer sliding winches myself. Sometimes you want or need a strap right in this or that exact spot...
    I remember trying to strap down a load of super sacks of some powder or another, the pallets weren't 48 inches exactly, I think they were 42 inch pallets with a little extra space where the sack bulged out but it worked out to less than 48 inches, and where some of the straps went nicely over the center of the sacks, at another point in the load the straps were in spots that it would just slide off of the sack one way or another.
    Also sometimes I get loads where I prefer to use more straps in a concentrated area than the fixed trailers have. I guess it depends on what you haul, but I love sliding winches.
  10. Locked winches work for specific load application.
    Sliding winches work for variable loads.
  11. Zeviander
    4,886
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    I was talking about over axles. We have a lot of trailers spec'd that way. Fixed over tires, mobile everywhere else.
