LTL 48ft Or 53ft Trailer
Discussion in 'Refrigerated Trucking Forum' started by Freeway48, Mar 19, 2020.
  1. Freeway48
    Freeway48 Bobtail Member
    5
    4
    Mar 19, 2020
    Working on my authority and decided I wanna pull refer preferably LTL I want to be knowledgeable and do all my homework before I make any moves. I got a great deal on a 48ft Great Dane but I don’t wanna run into issues on getting loads. Also I been looking into different brokers I was told H&M is a decent one to start with. Any advice, or tips are greatly appreciated
    Farmerbob1 Thanks this.
  3. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Have a lot off cash in reserve.
    alds, Zigzag777, Farmerbob1 and 2 others Thank this.
  4. 062
    062 Road Train Member
    6,332
    33,972
    Oct 20, 2013
    If all you plan to do is ltl, then you can get by with a 48. You’ll some what limit yourself by not having a 53 doing truck load. I’ve loaded some Sysco corporate stuff that’s between 40-50 pallets.
    Farmerbob1 and Freeway48 Thank this.
  5. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    Refer go with a 48 spread axle if possible. You don't need a 53 for temp controlled loads. Temp loads tend to be on the heavy side, and even in a 53 you don't want to load past the 42' mark anyway
  6. 062
    6,332
    33,972
    Oct 20, 2013
    I do ltl and 95% of the time it’s loaded to the back door. Average is around 32 pallets.
    Big_D409 Thanks this.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    The last company I worked for before becoming an O/O ran both 53 and 48 reefers on LTL. I have to admit, the 48's were kind of nice. I'm based in California, and you can run the tandems all the way to the rear on a 48 and be legal, and they really hold about the same amount unless you haul light produce loads where they load pallets all the way to the doors. As an O/O I'd probably stick with the 53. I'd hate to miss out on loads because of a short trailer. I know you're planning on LTL loads, but I think you'll find after you get into it for a while that the full loads are much easier to get and pay just as well in most cases. I do LTL for a contract client, but my back hauls are always brokered loads and many require a 53.
  8. hookster359
    hookster359 Light Load Member
    106
    175
    Sep 20, 2009
    mn
    If it was me I would do the 53 because you never know when you will get a load where you will need the space. I bought a trailer years ago and it was a 48' by 96" wide instead of buying the 48' by 102" and ended up many times I couldn't load the trailer because it wasn't wide enough so I look at it buy the 53 and than you have it and when it comes time for resale you should have a better chance of selling it.
  9. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    With doing LTL, I’d aim for a 51’ spread or independent sliding spread. I loaded 30 pallets weekly when I ran mine, then 28 pallets on my way back. Just make sure you get a 102 wide and be mindful of interior specs.
    GoldenLad, Farmerbob1 and Freeway48 Thank this.
  10. abyliks
    abyliks Road Train Member
    4,126
    9,720
    May 2, 2010
    ludlow MA
    Better to have and not need then need and not have, 53s are a lot easier to find too
    alds, Farmerbob1 and Freeway48 Thank this.
  11. Freeway48
    5
    4
    Mar 19, 2020
    Appreciate that guys I think I’m gonna play it safe and go with a 53 spread axle. I got a list of brokers to start off with until I build the contacts to go fully direct if y’all have any other brokers I should give a call to please let me know
