Lube for binders
Discussion in 'Flatbed Trucking Forum' started by D.Tibbitt, Mar 15, 2020.
  1. D.Tibbitt
    157,230
    Wondering what u guys use for the best lube for ratchet binders. I have litteraly tried everything but run into the same problem each time. They either dry out or get gunked up or both.
    The best i have found is just basic liquid wrench or any pentrating oil.
    I have tried so much different kinds of grease but they all get gunked up, especially running open headache rack.
    Had a guy tell me to use the lucas hub oil and that turned out to be worse than the grease, welded my binders shut, had to get a hammer to break them open.
    The only problem with penetrating oil is that it dries out after u have them on freight, and doesnt really protect it against road salt or other elements.
    My next experiment was gonna be with some motor oil .
    What do u guys use or had luck with ?
  3. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    I use Fluid film on my ratchets for my car hauler.
    Stays a long time and doesn’t harden.
    It comes in an aerosol can and you just spray it on.
  4. MM71
    MM71 Heavy Load Member
    760
    992
    Jun 28, 2008
    AZ
    Gear oil ...
    If you want to spend extra money chain wax (motorcycle chain lube) or as mentioned Fluid Film ...
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I use Lucas 5th wheel/slider lube in the summer and 90w gear oil in the winter. 90w would probably work just as well if you used it every other load to flush out the dirt. I just like the bottle shapes for easy application.
    I always wanted to try CV axle grease but never got around to it...
    singlescrewshaker, cke and D.Tibbitt Thank this.
  6. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    PB Blaster after every use or a little Motorkote, but PB Blaster is waaaaay cheaper
  7. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    Two stroke oil not bad but I use 90 weight once a month than wd40 in between keeps them from guming up!!!
    singlescrewshaker and D.Tibbitt Thank this.
  8. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    White lithium grease is also good!
  9. D.Tibbitt
    157,230
    I ne ver had any luck with those . White lithium gummed up on me after awhile. Not as bad as the grease but after a couple applications i didnt use it anymore. Think im gonna try the gear oil or some heavy weight oil like u said and see how she holds up !!
  10. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    I used WD40 to get them oiled up, then I sprayed them with silicone spray for work boots. With those 2 combined it repelled the water & road junk really well for about 2 weeks, then I had to do it again. Not a perfect solution but it worked
  11. solitary_con
    solitary_con Light Load Member
    147
    137
    Mar 2, 2007
    Cook County, IL
    That's the only thing I found that works.
