Many issues t660
Discussion in 'Kenworth Forum' started by Rayj00, Jul 7, 2024.
  1. Rayj00
    Rayj00 Light Load Member
    57
    38
    Jan 19, 2024
    My son is a driver for Stevens. T660 He has an intermittent problem of the following symptoms:
    No AC in the front
    Can't adjust mirrors
    Can't roll windows
    Headlights won't shut off
    Dashboard switch lights are out
    This happens all at once and intermittently. He's in Georgia and it's getting hot outside!
    Ideas?
    blairandgretchen Thanks this.
  3. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    Try disconnecting the batteries for 10 minutes. Sounds like a body controller issue.
    ducnut and Opendeckin Thank this.
  4. Rayj00
    57
    38
    Jan 19, 2024
    He did that yesterday. Same problem. But now out of no where the windows just stated to work. But they are out again.
  5. blairandgretchen
    13,966
    76,813
    Dec 9, 2011
    South west Missouri
    Mirrors not adjusting is arguably a safety issue - if it's a company truck I'd be getting them to arrange a relay for the load if he's under one, and headed to a shop to fix issues.
    And driving in the heat is not a great safety idea either, you get fatigued a lot faster and lose focus.
    Diesel Dave and Rayj00 Thank this.
  6. TJB15
    TJB15 Light Load Member
    67
    115
    Apr 29, 2020
    I have a 2013 t660. Sometimes the dash lights won't light at all I'll unplug the two fuses that are labeled cecu (they are right next to each other about halfway up right hand side of panel) count to 30 or so and plug back in. Seems to work for that. Never have had the combination of problems you are describing.
    Rayj00 Thanks this.
  7. Rayj00
    57
    38
    Jan 19, 2024
    Is there a test the mechanics can run to tell there is an issue? I would think any issues with the truck should be logged by the computer?
    Son is headed to Dallas to swap out trucks. The issue is currently back.
  8. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    The BCM controls all that. The shop can try a BCM update, but, chances are it’ll just happen again, until the BCM is replaced. And, most shops won’t replace any module, without a solid diagnosis, which isn’t possible to do, especially with the incompetent work force in most shops. On top of that, it’s a POS PACCAR product and PACCAR probably won’t cover it under warranty, despite them knowing they have a problem with their junk trunks. We have several of them with the same problem.
  9. Rayj00
    57
    38
    Jan 19, 2024
  10. Rayj00
    57
    38
    Jan 19, 2024
    Not sure what BCM is, but thanks for the response.
  11. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    CECU (BCM) is a module located under cup holder in bottom center of dash. As far as modules are concerned they do go bad often. Quite expensive, so pay someone who knows before you buy one. Does sound like it may be your issue.
    ducnut Thanks this.
