Mirror turn signal
Discussion in 'Peterbilt Forum' started by Shane388, Jan 6, 2022.
  1. Shane388
    Shane388 Bobtail Member
    6
    Hello I have a 2013 388 which I’m trying to hook up turn signals on the mirrors I used the factory wiring that is pre wired for the running and turn signal lights but I’m having trouble with the lights messing with the cb every time I turn the parking lights on or turn signal it makes the cb go all static I’ve tried every place I could think of in the dash for a ground has anyone had this problem?
  3. blairandgretchen
    13,933
    76,584
    Dec 9, 2011
    South west Missouri
    What about a noise suppressor for the CB power feed?
  4. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    The problem is the LED lights you bought to put on the mirrors its not in the wiring..
  5. Shane388
    6
    They are 4 inch led lights lollipop lights is what I call them. Do they make a special light for that setup?
  6. Last Call
    7,568
    45,912
    Mar 15, 2021
    This is what I learned when I was looking for LED turn signals for a 359 I have.. The cheaper LEDs cause interference with FM radios & CBs I got to reading alot of reviews and had heard about the problem from some other drivers I know.. give me a little bit and I will post the ones I got from Dirks I have had no issues with them ..
    Bean Jr. Thanks this.
  7. Last Call
    7,568
    45,912
    Mar 15, 2021
  8. Shane388
    6
    Ok cool thank you very much. The ones I got where from Amazon so they are definitely on the cheaper side of things.
  9. Last Call
    7,568
    45,912
    Mar 15, 2021
    No problem...I can't take credit for the info thou..another member here hooked me up with the info for those lights.... the issue I had was originally turn signals on a 359 were just turn signals I wanted LEDs that were turn/running lights
    I looked all over Amazon & Ebay found alot .. but most had bad reviews about either longevity & or static interference
  10. Shane388
    6
    Hey any information helps right at the moment I’m kinda stumped and frustrated lol
  11. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Maxima LED has quite a good selection
    But they are not cheap
