Misterious air leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 10, 2024.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I've got air leak somewhere that i can't find. I've replaced couple quick connect fittings that were leaking and it's better now but still air escaping somewhere and I can't hear it. I've sprayed air bags air lines. I've released brakes and listened for air leaks and still nothing
    I was wondering if I can hook up smoke machine to air tanks and see if smoke will travel through system and might be able to find air leak that way?
  3. 062
    062 Road Train Member
    6,332
    33,971
    Oct 20, 2013
    Never tried that.
    Which side is leaking primary or secondary?
  4. Diesel Dave
    9,683
    32,901
    Jan 20, 2010
    Hesperia, Ca.
    I gave up looking for mine. I’m good if I keep enough air for about an hour.
  5. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Type of truck..?
  6. mitmaks
    2,586
    2,102
    May 16, 2014
    Both sides leak. It's 2013kw t660 so primary tank fills up first then 2ndary starts filling up
  7. 062
    6,332
    33,971
    Oct 20, 2013
    When you checked the air bags were you loaded?
    Did you put your ear up to each brake chamber listening for leaks?
    mitmaks and Oxbow Thank this.
  8. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    They sell these microphones on a stick that you can use to magnify sound. Might be able to find it that way, if it bothers you that much.
    blairandgretchen and mitmaks Thank this.
  9. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    I've two over the years that took a while to find. One was a line behind the dash and the other was underneath the seat for the air ride.
    mitmaks Thanks this.
  10. Concorde
    Concorde Road Train Member
    5,482
    19,487
    Jun 29, 2016
    West Melbourne Florida
    Guessing that your truck is plumbed the same as the 2014 t-680 I got rid of.
    Let air build up, set brakes and then shut it down.. Watch the gauges..once primary tank gets down to 90 it’ll stop feeding your secondary tank. At this point you should be able to see if the primary or accessory tank is leaking by whichever tank keeps dropping.
    Imo, you just have push fittings that are worn out and leaking.. I had to replace almost every one on my 680 after 5-6 years. Colder weather makes them worse..
    Personally I’d just get a spray bottle filled with water and a lot of dish soap ( I keep one filled in my truck) and start checking every single one.
    Could just have a bunch of slow leaking fittings vs on big leaker. Only issue I had replacing some fittings was there not being enough slack to trim a half inch off the ends before putting the new ones back on.
    062 Thanks this.
  11. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    I’ve mentioned this in many other threads and usually get blown off but I have found that 80% of mysterious silent air leaks are thru the transmission. The solenoids or the range selector or splitter valves will leak and let air pass into the trans and leak out of its vent. To prove it years ago i put a ball valve on the trans supply line on one of my trucks that would not hold air for half a day even after everything on air system was tightened up. With air shut off to trans when parked truck will hold air for weeks now and it takes a full week before it drops from 120 to 60. Has air ride. If i leave valve open it is down to zero in a few hours time.
    Another thing is seats. They leak over time. Put shutoffs to them when not in use. But air shifted trans are big culprit's.
    BoxCarKidd, D.Tibbitt, mitmaks and 3 others Thank this.
