Mixing synthetic gear oil with regular
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 4, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,834
    27,123
    Dec 8, 2017
    When what is my rears I put full synthetic in the other I put regular gear oil because I wanted to run it for a while and then flush it.
    Well it turns out that I got mixed up and I added some regular gear oil to the synthetic.
    I'm sure I added less than half a gallon probably more like a quarter I guess or 1/3 but should that be drained and put all synthetic in?
  3. Judge
    95,756
    Yes, you can safely mix synthetic and conventional oil. ... In the end, conventional and synthetic oils are completely compatible. However while you can safely mix synthetic and conventional oils, you're diluting the performance of the synthetic oil.
  4. I glide 47
    I glide 47 Road Train Member
    1,426
    1,524
    Jun 3, 2017
    All engine oil have regular synthetic and synthetic blend, I know you are talking about gear oil but it will be fine, funny thing is that shells rotella.oil their blend gets the best fuel economy of their 3 oils
    Rideandrepair and Dino soar Thank this.
  5. Claytonbigsby
    Claytonbigsby Bobtail Member
    47
    114
    Mar 31, 2019
    Not all synthetic gear oil is compatible, PAO based synthetic will blend with conventional oils, polyglycol based will not blend
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,612
    6,771
    Aug 26, 2014
    Searching that can lead to a long study. Short study appears that is normally used in the food industry?
    Never saw or heard of a problem mixing common petroleum and synthetic truck oils. Told that a little petroleum in synthetic losses all the synthetic advantages.
    Petroleum and mineral oil makes mud. Have heard and seen that.
    Have no idea what synthetic and mineral oil makes.
    If in doubt change it out.
    Rideandrepair Thanks this.
  7. Dino soar
    4,834
    27,123
    Dec 8, 2017
    I just looked at the pale for the synthetic oil and all that it says is that it is a petroleum product.
    I'll have to take a look on the bottle of actual regular gear oil but I can't imagine they're not compatible.
    Yet oddly enough I'll probably run the truck as it is for now but change it with the next greasing.
  8. BoxCarKidd
    4,612
    6,771
    Aug 26, 2014
    When I worked for a fleet in the early 80's they used synthetic gear oil. Said Rockwell warrantied trans and rears for 750,000 miles with synthetic oil except for abuse.
    That oil was orange to red colored and had a distinct smell.
    Rules for synthetic have changed. I have had new buckets that the oil was dark and smelled like the oil out of a 40 year old diff. I changed suppliers.
    The oil I am using now is almost clear, labeled for all the specs and about $105.00 for 5 gallons.
    Dino soar Thanks this.
  9. I glide 47
    1,426
    1,524
    Jun 3, 2017
    Synthetic oil is petroleum oil,difference is the refining and additives,
    Bean Jr., '88K100 and Dino soar Thank this.
