MX 13 coolant sensor ???
Discussion in 'Ask An Owner Operator' started by GYPSY65, Aug 6, 2024.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,266
    Nov 16, 2012
    SW FLA
    I have an issue with the sensor
    it will ding. Turn red. And say stop truck
    coolant is full
    I can remove the sensor and put it on a bottle of water and no issues
    what’s the problem??
  3. Big Road Skateboard
    7,160
    40,557
    May 2, 2021
    Coolant reservoir likely
    GYPSY65 and Judge Thank this.
  4. Judge
    92,413
    I had to change the entire reservoir tank.
    the sensor was inside it and it’s going to be bouncing around.,
    Check partsgeek, i got tank for $120 vs everyone at 150-200 for 579 pete
    Diesel Dave, GYPSY65 and Siinman Thank this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    I had that problem on a w900. I just unplugged the sensor. But it had the old style radiator. No reservoir.
    Can the same thing be done with the plastic reservoir?
  6. GYPSY65
    1,957
    5,266
    Nov 16, 2012
    SW FLA
    I have it unplugged, but it’s like a half of a straw type tube and that has to be in some sort of liquid
    I have that in a bottle of water
    I think there is a way to bypass the sensor with the paperclip, but I have not been able to get that to work yet
  7. Judge
    92,413
    i couldnt get mine to stop beeping.
    It’d run and not shut down but that annoying beeping lasted a week until i got back in.
    Siinman Thanks this.
  8. snowwy
    20,612
    13,333
    Jul 6, 2009
    I wouldn't try a paperclip. That actually ruins the plug by making the holes bigger so you won't make a good connection.
    That w900 I did that trick on didn’t have the speaker connected.
  9. Arctic_fox
    4,529
    25,632
    Sep 16, 2016
    Had the same issue and judges solution was pretty much what i had to do. Only diffrence is i got my tank from the dealer. Was iirc $180.
    Vampire, GYPSY65 and Judge Thank this.
