Anyone know where I could get a bulk head somewhere between OKC and Fargo, ND? All the Carrier and TKs I've called say they need to be ordered. New or used, doesn't matter.
TIA
Need a Bulk Head ASAP
Discussion in 'Refrigerated Trucking Forum' started by mrbamcclain, Aug 28, 2013.
Removed my post. Thought you were looking for a flatbed bulkhead.
Home depot,ect. Foamboard and load locks.
mrbamcclain Thanks this. -
I've seen the foam board used before, matter fact I've had a shipper put it in once. Seemed to work ok. Might have to try it myself until I get something more durable and permanent.
^^^^^This. 2 pieces of foam board and some packing tape will work perfectly. Although the packing tape is a pain in the ### to remove, it would seal better than load locks alone, and you wouldn't risk the chance of it falling down.
ITWIP.COM--take ur time ck them out--order what is BEST4 ur applications--for now home depot--insulated boards and tape will work just fine--get the kind with the shiny aluminum type on one side--point that side towards product to stay cold--helps insulate better that way and if u r careful w/it it'll last more loads than u think--have fun
mrbamcclain and Panhandle flash Thank this. -
http://www.thebulkheadpro.com/home.html
Used and will ship.mrbamcclain Thanks this. -
http://philadelphia.craigslist.org/cto/4041965915.html
Might wanna check this outmrbamcclain Thanks this. -
Looking for a load to Philly tomorrow! Thank you much
'olhand Thanks this. -
Check with Thermo King Christensen in Omaha, Ne. Just looked at one of their monthly flyers and they had used bulkheads for cheap.
A.C.
