Need Engine Advice
Discussion in 'Ask An Owner Operator' started by mikey747, Jun 10, 2020.
  1. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    X15s have been around for about 3 years now haven't they?
  3. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    ISX isn’t a bad motor but if your the 2nd owner then buy the Encore XT1 2nd owner warranty from Cummins just in case.
    Ideally, go with the newer X15 Cummins. It’s a great engine.
    PE_T and mikey747 Thank this.
  4. mikey747
    mikey747 Light Load Member
    60
    20
    May 13, 2016
    Thank you for the reply, that is a great piece of advice
    Midwest Trucker Thanks this.
  5. SUPERFASTSALEEN
    SUPERFASTSALEEN Bobtail Member
    15
    18
    May 20, 2020
    Mc Farland CA
    DD15 all day man. Bought my DD15 with 450K miles now 810K and still running like day one. Just make sure you keep good maintenance on it, and EXTREMELY IMPORTANT... USE QUALITY OIL...
    mikey747 and PE_T Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    2018 MX13 and 2019 X15 still happening.
    These were both being used for super B trains, 140,000 lbs.
    Long FLD Thanks this.
  7. Judge
    92,615
    I have a 13 ISX Cummins with 897k miles, it has never had a rebuild.
    Oil change every 12-15k miles with Lucas.
    So according to that post, I’ve more than doubled the statistics.
  8. Long FLD
    Long FLD Road Train Member
    12,935
    54,276
    Mar 4, 2015
    I think so.
  9. JerzyG
    JerzyG Light Load Member
    93
    265
    May 23, 2020
    Do yourself a favor and find something pre-egr...you will save a lot of money and headaches.
    mikey747 Thanks this.
  10. AModelCat
    164,938
    Do the new X15s sound like they're going to chuck a rod like the later year ISX?
  11. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    All have their good and bad .
    No engine is perfect.
    Maintenance matters.
    Next is luck.
    Do you know how heavy you will run?
    If you plan on running a lot off light loads i would be carefull to buy a 15l engine.
