Ok so I have a thermo king sb 210 2007 I have my thermo king preset to 34° and it’s running at 39.9° my brother has the same reefer but it’s a whisper his is running at 34.5° same load my load has a temp tracker in it if they catch me on these temps they will think I’m in cycle and I can’t get in trouble can someone help on how to fix the difference in trailer degrees
Need help ASAP on my reefer
Discussion in 'Refrigerated Trucking Forum' started by Refferandtrucks, Aug 11, 2020.
Try turning the set point lower and run continuous until you find that temp that maintains the trailer temp you need.
You need to confirm what the actual numbers are. It’s possible that it’s at the right temp but showing a wrong number.
I always keep a thermometer in the rear vent door. Depending on if the product was hot or at temp, then it should read within a degree or two of the return air temp. -
First what is the load? Some loads are fresh HOT and take time to cool down. Heck I got a -10 load on right now and not even at -1 yet and it's been 24 hours. This load was hot when put in my trailer.
rachi Thanks this. -
What temp was the product when you loaded
You can't change the previous info on it.Have you defrosted it since loading?
I need your help my guy
Is it working now?
The whole load might be rejected when he gets where he's going. Like the said, defrost it first off.
Idk about thermokings but see if you can turn the airflow to high and see if that works, if not then turn of the fresh protect mode.
