Need help finding violation/penalty info for Air Springs
Discussion in 'Trucking Industry Regulations' started by haulinasphalt, Feb 12, 2020.
  1. haulinasphalt
    haulinasphalt Bobtail Member
    47
    15
    Nov 23, 2010
    I have a local running Class 7 truck with two air springs, both with cracks/separation on the tops of the bags. The air bags do indeed hold air and do not leak (yet.) Nonetheless, I reported the issue to my supervisor for repair. Long story short, my supervisor thinks I might be over-reacting (yes, I showed him the pictures) and has requested to see the official FMCSA compliance info and how this issue is considered a violation and the penalties for such. The problem is, I cannot find any violation information pertaining to the air springs specifically, let alone cracked air springs. Does anyone know where to find info pertaining to this specific issue? Many thanks in advance!
  3. Judge
    94,207
    Tip, sometimes with bags deflated, a sharp object could put an airleak into a dryrot cracked area, then would need changed.
    Or stop at a set of scales and ask if one of the officers has time to inspect something, then it will show up on vehicle maintence and not against you, since its not your company.
    Included:
    393.207 Suspension systems.
    (a) Axles. No axle positioning part shall be cracked, broken, loose or missing. All axles must be in proper alignment.
    (b) Adjustable axles. Adjustable axle assemblies shall not have locking pins missing or disengaged.
    (c) Leaf springs. No leaf spring shall be cracked, broken, or missing nor shifted out of position.
    (d) Coil springs. No coil spring shall be cracked or broken.
    (e) Torsion bar. No torsion bar or torsion bar suspension shall be cracked or broken.
    (f) Air suspensions. The air pressure regulator valve shall not allow air into the suspension system until at least 55 psi is in the braking system. The vehicle shall be level (not tilting to the left or right). Air leakage shall not be greater than 3 psi in a 5-minute time period when the vehicle's air pressure gauge shows normal operating pressure.
    (g) Air suspension exhaust controls. The air suspension exhaust controls must not have the capability to exhaust air from the suspension system of one axle of a two-axle air suspension trailer unless the controls are either located on the trailer, or the power unit and trailer combination are not capable of traveling at a speed greater than 10 miles per hour while the air is exhausted from the suspension system. This paragraph shall not be construed to prohibit—
    (1) Devices that could exhaust air from both axle systems simultaneously; or
    (2) Lift axles on multi-axle units.
  4. AModelCat
    166,492
    To me, its time to change them.
    How cheap is that company? Geeze airbags are like $100 each lmfao.
    Shawn2130 and Studebaker Hawk Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I agree those bags are tired. Change em.
    Shawn2130 Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,634
    13,356
    Jul 6, 2009
    There's no such thing as air springs.
    If they don't leak. They're still good.
    You'll learn in this business that boss's don't believe in spending money on preventive maintenance or repairs.
    They have no choice with repairs. You'll just have to wait for a leak.
    If it ain't broke. Don't fix it.
  7. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,901
    Sep 20, 2015
    Southern Ontario
    I’d rather replace them before they blow.
    It’s not just a matter of putting off money, I really don’t want to be parked in the wrong spot along a busy highway, a construction zone with no shoulder and people zooming by at 80 mph.
    Besides, I’m sure the mto in Ontario will consider that a need to be replaced as it’s cracked and ready to fail.
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    You'll know when they blow, it sounds just like a shotgun at an indoor range. Had one blow standing still as I was walking past it. I jumped a bit, then walked inside to schedule the replacement.
