Need help understanding "New" codes in Paccar engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Guntoter, Jul 26, 2015.
  1. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    **Spngebob squarepants announcer** "Meanwhile 6 weeks later...... " If you can't make a living working 1 or 2 days a week you better stay away from Paccar.
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I am just thinking this way. We can connect Davie and clear codes. Then we can leave ignition open and Davie connected. We will try to shake/move wires, connectors. At one point the codes will come on again and that area could be faulty/loose place..
    daf105paccar and Guntoter Thank this.
  4. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Good idea, I will ask Rush to do that. Thanks.
  5. Cat sdp
    Cat sdp . .
    21,321
    76,359
    Apr 8, 2012
    Orion's Belt
    My local kw dealers shop is always full of those engines all with some form of emissions problem......
    Drop a tree on it (or let the dpf burn it to the ground) and be done with it..
    77fib77 and NWAF Thank this.
  6. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    the burning option is more realistic..
  7. AModelCat
    165,353
    That is the problem with the computer generation. The little scanner tool says this part isn't working right so they change it. What they don't seem to realize is that there are half a dozen other things in most cases that will cause a particular fault.
    91B20H8 Thanks this.
  8. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Guntoter, I know off a case similiar to yours,aldough it was not emmissions problem.
    There was doubt about the ecm.
    That dealer installed a new one with agreement that if the problem was not solved, they would reinstall the old one.
    You think you could talk Rush into doing that?
  9. supersnackbar
    20,268
    53,872
    Aug 19, 2007
    Your Town, USA
    Hire a Swift to turn too tight and catch the hood with the middle of his trailer bad enough to damage the engine , then hire a CRE to back into whats left. Then insurance will total it, Swift and CRE pays for it, and the problem is solved :)
    TRD, mhyn and 91B20H8 Thank this.
  10. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    MegaDrivers would not do that. it's just your imagination...lol
  11. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    The third time I went in I asked about a "loaner" ECM, they said they can not do that. The ECM is a "one time use" part, meaning that once it is programmed to the truck, it lives in that (only that) truck for ever. When I suggested that it was an ECM issue, they said they would sell me an ECM at cost ($3,200) but once it is in the truck, I own it (no return).
