New Antenna Time
Discussion in 'CB Radio Forum' started by Frank Speak, Jan 5, 2019.
  1. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    i hit a low hanging limb and it snapped my antenna. I went into Loves and bought a Francis 4 footer.
    I’m not the arbiter of CBs, but have to say. My stock classic 29 LTD never sounded better. It transmits farther and receives even father. Couldn’t be happier.
    In fact, the only thing that would make me happier is if I knew of some way to give me about a 5 mile transmit/receive radius. :)
    IluvCATS Thanks this.
  3. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Find a good cb shop and get your radio peaked and tuned.
    Frank Speak and IluvCATS Thank this.
  4. Ridgeline
    22,730
    123,538
    No don't get the radio peaked and tuned, there is no reason for it until your get the antenna system checked and tuned up.
  5. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    There's no such thing as shortcuts in life. Mastering your antenna system is going to be the most important thing you ever do to achieve your desired results. If you can't get 20 miles out of a stock Cobra 29 no amount of tweaking or tuning of the radio is going to compensate for your inefficient antenna system.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    "IF" you had a Predator 10K and broke it hitting something, you wouldn't have had to buy a new antenna! The Predator 10K antenna's have a lifetime warranty so if you break it, they will send you replacement parts or a new antenna for FREE!
    Plus, 5 mile radius is no problem with a Predator 10K... (provided you have it properly tuned and mounted in the correct place.)
    mslashbar Thanks this.
  7. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    “Where” to mount antenna on big truck is everyone’s problem.
    Given that it’s a company fleet truck, the places that are both secure and able to produce results can be counted across a few fingers.
    We are pretty much limited to available aftermarket antenna mounts.
    So the best mount, the best antenna type (design & brand), and higher quality coaxial cable than is factory-provided is just about the end of it.
    But as the Rabbi indicates, it’s still details that matter. Quality of installation work, for example.
    Cable securement, weathertight seals, etc.
    Then to power. Accessing 12VDC from a source not compromised by truck electrical noise. Proper supplies, tools and execution.
    It all starts somewhere. Hasty work may provide nothing. Cause problems.
    Some time in research and laying out a plan is the thing.
    wolverine11 Thanks this.
  8. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    You failed to mention what type of truck you are driving and are you currently using the stock antenna mount and coax? From my experience the stock setup on a Volvo or T680 is average at best and Tx/Rx range will average around 5 to 10 miles, now if you are in a newer Cascadia you will want to use a seperate mount and coax for better performance.
    Frank Speak Thanks this.
  9. wolverine11
    1,628
    1,234
    Apr 1, 2015
    Well obviously you are not driving a newer Cascadia or you wouldnt of been able to install a new antenna because the stock antenna is integrated into the roof.
  10. Frank Speak
    4,583
    14,117
    May 3, 2016
    It’s a 2015 Pete 389. Not using the stock coax. The coax was installed when the radio was installed (about a year ago).
  11. wolverine11
    1,628
    1,234
    Apr 1, 2015
    Maybe now someone with experience with that particular truck can chime in with what type of setup will work best, Ive never driven one.
