No food! No water or bathroom and expected to stay in truck
Discussion in 'Swift' started by bluebonn, Jan 16, 2011.
  1. bluebonn
    bluebonn Road Train Member
    1,026
    723
    Aug 21, 2010
    Texas
    Oh well Oregon got me today as soon as I entered the state on 82. Did a level 2 and I failed. Let me explain a little of what went on today. last night I pull into the Sumner terminal and need to get a new tire to replace the spare that was on my drives.
    The mechanic at the shop was really nice and did the job. I asked him when he put the spare back in the holder to make sure he put my clip back on. Get up the next morning and deliver to Costco and pick up a new trailer loaded down the street going to Utah. Well finally I might have a decent day.
    Well I knew that on this load I would either have to take a 34 in Pendleton Oregon or wait until 12AM on Saturday to get 11 hours back and then the next day get another 11 back and still get the load there on time.
    So I get to exit one and the prepass starts going crazy with red. Pull into the scales and inch my way onto the scale and the light turns red for me to stop. Then I noticed the guy come out and look between my truck and trailer.
    I get the pull around sign and told to bring in all my paperwork. Get in there and I am wondering why and found out real quick that he pulled me around because my spare was not secure.
    Well it was when I left this morning but apparently the clip was never put on by the mechanic so the chain found it's way loose. He checks my logs and kept asking me about when I was in San Antonio about me dropping a trailer then going off duty and then coming back on duty and hooking to one an hour later.
    I told him I went into the break room and they did not have my load ready. I said isn't that what the paper at the front of my book says that I have permission to go off duty for breaks? Then he said yes after seeing it.
    So we stroll on outside so he can inspect the truck. I had no worries because I checked both the truck and the trailer out before I left. Well we get to the lights on the trailer and he said your ABS and your side markers are not working.
    Well they where working when I left this morning. So we go back inside and he fills out the form noting 3 violations::
    Failure to secure vehicle equipment
    ABS malfunct lamps not working
    Inoperable required lamp side marker on both sides
    Then he explained to me that I should never ever trust someone else to do anything. You are the one responsible for that tire being secure and if that tire would have come off you could have killed my family or someone.
    Talk about making me feel bad! he said that the ticket was $450 but this time he will let me slide with a warning. I was like thank you! So I pack up all my things and he said you are out of service until you secure the tire.
    I go out and this time I make sure the chain will not come off. Poor other driver in there was not as lucky as me as he got a ticket for being over weight. So he finally lets me go and on the way out he said where are you planning to shut down. I said pendleton.
    He said make sure you do because you are almost at your 70. Man I was sweating bricks while he was looking at my logs. I thought for sure that he was going to find the ones where I went over my 70 two weeks ago that Swift informed me of.
    So I go and pull out of there and I will be #### my ABS and side markers came on and have stayed on every since. What's up with that? They quit working when I get an inspection but they work when I did my pre-trip and now.
    So I learned today to never trust a mechanic always double check that could have cost me $450. I don't understand why that spare is even on my truck it will never pass inspection. I tried to get another one at the shop but they would not give me one. They just said I cannot believe they put that on your truck.
    So now I sit and wait until I have hours to run. I averaged out my miles today and I have averaged 2900 miles a week. I am always hitting my 70 so I have no idea how not to do this and keep the miles I am getting. remember I have only been solo for a little over a month and I took four days off. Well three technically but I got a free day on that Monday because I got Un loaded early. So I was off last week from Monday to Thursday.
    I just came back from time off Friday afternoon and I hit my 70 earlier today. So any pointers will help as I hate sitting!
    Rotten Thanks this.
  3. Injun
    Injun Road Train Member
    8,501
    9,492
    May 15, 2010
    West o' the Big Crick
    Regarding those lights: the ABS light is only supposed to be on if your ABS is not working right. It comes on for a few seconds when you first start the truck, but otherwise stays off. Side marker lights: do you have one of those trailers with the separate turn signals on the right side that aren't supposed to be on unless you're turning right or have your 4-ways on?
    If you have trouble with your pigtail wiggling around, get a bungee cord, hook one end onto the bracket the air brake connection hangs out on, wind the bungee around the pigtail and connection cover a couple of times and hook the other end onto the other air brake bracket. It should be tight enough to keep your pigtail plugged in. Some guys zip-tie the pigtail, others tape it. I hate it when they tape it, especially in the summer time. It makes a big gooey mess.
    The tire? Yeah...should have checked that one.
    Regarding log pages: get all log pages out of your book except today and the previous seven days. It's all you are required to have. Keeping log pages prior to that when you know there's a problem with them is asking for trouble. It's like volunteering information. No need to do that.
    And telling you you're up against your 70. Really?!? Seriously?? Maybe that's why you were headed to the truck stop??
    inkeper, Big Frank and Rotten Thank this.
  4. bluebonn
    1,026
    723
    Aug 21, 2010
    Texas
    Yea I checked the pigtail and everything seems to be OK. So what you are saying is if I have the blinkers on the side then the only time the light comes on is when I use the turn signal?
    The ABS light should only come on when what a issue happens with ABS? Right now I have the ABS side markers coming on and the sidemarker turn signals work properly.
    Yea the tire that was my fault for not double checking that the mechanic secured it with my clip. Like they say you learn something new everyday. I never looked at the spare because I did not think I had too once it was secured. Now I know it should be checked everyday just to be sure when doing a pretrip.
    That was one expensive ticket if he did not give me a warning. Yea I don't know why he mentioned the 70 because I was fully aware that I would have to stop in Pendleton.
    This was the very first trip I actually had time to plan it out. Now I just got to keep myself out of the Wildhorse Casino right next door but their dinner is so so tempting.....
    Thank you for the advice on removing the logs. I have every one of them in there from the time I started... Now I will only have 7 days.
  5. inkeper
    inkeper Road Train Member
    1,440
    1,059
    Jan 30, 2011
    Texas
    Blue...another thing to check when lights are not working on the trailer, the pins in the connection box. Sometimes they get compressed. There is a pre-existing slot between the prongs of each pin. I use the blade of my pocketknife to GENTLY separate the prongs to insure a good connection with the pigtail. I stress gently because if you break the prong off you are screwed.
    Rotten Thanks this.
  6. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    Well, the ABS light is not supposed to work-- but let me explain-- during your pretrip when you plug in the pigtail, quickly glance down the side of the trailer to ensure the ABS light comes on briefly and goes back off again. If it does not go on at all or stays on all the time, Houston We Have a Problem.
    OK my truck broke down the other day, no dash lights, ABS tractor dash light was on, Check Engine light was on, DPF light was on, and no driver information display-- time/mpg/idle info etc. So Swift breakdown calls and we discuss options etc, when we got to the ABS he told me to take the bulb out of the ABS trailer light. I told him of course the light was not on out there, just on my dash, and not the trailer ABS but the tractor ABS.
    My point is, sooner or later you guys will have a problem with the ABS light either not coming on or staying on all the time, Do Not Allow BreakDown to convince you to just roll with it or take the bulb out--- there's no proof they told you, they don't get in trouble, you do, and like the inspector said, people's lives are at stake here not Swift's bank account. Yes, never trust the mechanic.
    Yes I have one of those wiggly piggly tails. I see a big dent on the back of the sleeper where some dillhole drove off with it plugged in and stretched it out. Everything was fine until the rain then I get intermittent trailer ABS dash light flashing and all trailer lights go out momentarily. I tried everything, wrapping the blue and red air lines tight around to support it in there etc, but every little bump in the road this would happen. DUH I read Injun's instructions and tried it and it worked! I can't believe I never thought of that! Thanx!
    Rotten Thanks this.
  7. NYROADIE
    NYROADIE Heavy Load Member
    773
    471
    Jun 24, 2010
    Rochester NY
    Ever think he mentioned your 70 BECAUSE he saw you went over before? Could be he was a lot nicer than you know!
  8. bluebonn
    1,026
    723
    Aug 21, 2010
    Texas
    Yea he could have seen the mistake. He was a really nice guy and it helped that we where both from almost the same area in Texas. So I call onroad and they told me to run with it to the nearest terminal. That would be SLC.
    Hmm I won't get any hours back until after midnight so this means I most likely will be running at night. The ABS light on the trailer will not go off now.
    So I messaged my DM to see what she wants me to do. hell now is the perfect time to fix this because I cannot move until after midnight.
    Something feels strange when I come to a stop as I started noticing this last night.
    I am not upset about being pulled around because like I said I learned something that was very important. If I would have got a $450 ticket then yes I would be mad at myself and mad at the shop mechanic...
    scottied67 Thanks this.
  9. Jynxx
    Jynxx Medium Load Member
    502
    180
    Mar 16, 2011
    Cheyenne, Wyoming
    This has been a wonderful posting to read. What are they paying you per mile and what is your average per week? I'm thinking about going to orientation with them and have been pre-approved to do so and am curious what a new driver will be making once solo.
    Thanks! :biggrin_25519:
  10. bluebonn
    1,026
    723
    Aug 21, 2010
    Texas
    Depends on how much experience you have how much you make a mile. If you are coming out of school be prepared to only make .25 a mile. I had experience but got of the road for 17 years so I had to start all over again.
    I have only been solo for a little over a month and averaging 2900 miles a week. That is with me being off for four days as well and one 34 hour and numerous times in the first week sitting at the terminal for a day.
    All in all it's not too bad but wish there was more money to be had. Guess it will come in time but really need it now.
  11. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Scottied... you have a short inside the cable. The only way it's going to get fixed is to get a new pigtail cable.
    Bluebonn... you've got a failure in the ABS brake controller in the trailer - that's what the light is telling you. If you get pulled in for another inspection, they're going to hit you with a ticket for that.
    You can't just roll down the road to the next terminal with these kinds of problems - that's illegal. YOU need to stand up to your management and make sure this gets taken care of before YOU pay the penalty of running with bad equipment. Remember... this all goes on your tab now that CSA is in effect.
