No pressure after opening coolant cap
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Oct 17, 2022.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello I drive a kenworth t800 with a Cummins isx.
    I’ve never had this problem before but recently, there has been no pressure when I open the coolant cap. While the truck is running, I opened it today and again no pressure at all. Usually I would have to open it slowly to let gas out before opening it all the way. Anyone know what’s going on?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    check for leaks. check at the water pump, at the "weep hole"
    you can pressure sheck the system as well, that'll force out any coolant from a leak.
    make sure too, the system is topped off first
  4. Judge
    92,782
    Engine Fan On?
    blairandgretchen Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    If the temp is below 170. You probably won't have gas to release.
    Not that there's any gas to release.
    I always kick the fan on if I need to pop the cap for whatever reason. 170 or lower before I take it off.
    buddyd157 Thanks this.
  6. Joyce's Volvo
    Joyce's Volvo Light Load Member
    116
    153
    Jun 28, 2016
    Cap may not be holding, most are made with a prv set to pressure of x amount of relief 8,10,13 psi , should the relief spring break then the psi will be lower or none at all.
    Big Road Skateboard Thanks this.
  7. dunchues
    dunchues Medium Load Member
    558
    961
    Mar 23, 2012
    new brunswick
    Why are you opening it?
  8. snowwy
    20,612
    13,333
    Jul 6, 2009
    Supposedly there's only one cap these days and it's rated for 15.
    Reservoir cap.
    Unless it's an actual radiator fill with a cap.
  9. Big Road Skateboard
    7,209
    40,984
    May 2, 2021
    You're constantly removing the cap. Why are you constantly removing the cap?
  10. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    Are you undoing the Radiator cap? Or the expansion tank Cap..??
  11. Ridgeline
    22,752
    124,082
    Replace the cap, it is not working.
