No throttle response
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by draya93, Aug 13, 2022.
  1. draya93
    draya93 Bobtail Member
    39
    16
    Aug 25, 2021
    Have a 98 12.7 detroit. Yesterday, I had to jump start the truck. Had a miss and had throttle response. This morning, I put on new batteries and fired right up, but still has a miss and now no throttle response. Checked all connections and everything seems to be good. My voltage gauge shows 14v. All fluids are good. Any help is appreciated.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Have you changed Fuel filters yet? Check the wires at plug in at the fuel pedal? `
  4. Big Road Skateboard
    7,280
    41,480
    May 2, 2021
    Check power across your two small fuses. Check their ends also, and small ground
  5. draya93
    39
    16
    Aug 25, 2021
    They get changed every oil change, I’ve got about 3k more miles to go before my next pm. I was actually thinking of changing fuel filters since it’s an easy option.
  6. draya93
    39
    16
    Aug 25, 2021
    Will do, thank you!
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    One bad fuel stop can have you changing fuel filters 3 times a day till all of it gets run out of your tanks,you have to carry plenty spares in the side box.
    Concorde Thanks this.
  8. blairandgretchen
    14,016
    77,307
    Dec 9, 2011
    South west Missouri
    Connect software and drive for a cut-out test - if all else is OK, then cylinder cut out test for faulty injector?
    cke Thanks this.
  9. Rideandrepair
    17,583
    56,953
    Aug 8, 2015
    Any codes? I’d suspect the throttle pedal sensor itself. Maybe check it for power coming in first. I’m sure there’s a procedure for testing it with a voltmeter.
  10. draya93
    39
    16
    Aug 25, 2021
    I got the throttle issue resolved. It was a bad ground, and dirty battery terminals but still getting a rough idle. Going to change fuel filters to see if it helps
    baha, Bean Jr. and Rideandrepair Thank this.
