As title says, 5th wheel handle not staying in open position when uncoupling from trailer. I have been using vice grips to hold open while disconnecting. Would a repair kit with the springs and jaws fix this issue? Thanks for your time and responses in advance.
NoSlack II 5th Wheel handle not locking open
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EasttxDT, Feb 3, 2026.
look for a broken or missing spring under the front of the plate. Look at another 5th wheel.
dosgatos, Rideandrepair and tscottme Thank this. -
Do the jaws sometimes stay open, and the arm stay out? I'd first replace all the springs and see how it works then. I have the same problem that just came on, but it only happens when it's cold. 50°>, no problems. I've got a new spring kit and going to replace myself here in the next few days. I don't drop and hook. But it sucks at Walmart because they require drivers to disconnect during unloading.
Yes the jaws and latch stay open, when coupling latch wont stay open. Became a pain, lots of drop and hook. Thank you for the input, im going to try the repair kit, clean very well and regrease.
I would start with spraying WD-40 or PB Blaster underneath around all the pivot points and linkages. When opened one of the linkages is supposed to "fall" and keep the handle extended until closed. If there is a bunch of grease built up it could prevent that from happening.
Vise grips
Had the same problem I started using low temp grease it works a little better
When I had that problem, it was a broken spring.
I'm sure a combination of an old, week spring and the 5th wheel lube I use during the warmer months was the problem in my truck. I use Shaeffer's 5th wheel spray lube, and it's known for being problematic in cold temps.
