Oil Analysis?
Discussion in 'Ask An Owner Operator' started by WizeWeelz, May 26, 2021.
  1. WizeWeelz
    WizeWeelz Bobtail Member
    May 26, 2021
    I just read where doing an oil analysis can let you go longer between oil changes. Anyone having any luck w/ this?
  3. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    I do it to check for abnormal were
    blairandgretchen Thanks this.
  4. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    I don't use the analysis to extend my oil changes. I like to be aware of condition of my motor and I have an oil Spinner that removes soot from the oil.
    There are a lot of truck owners that use the analysis to extend oil change intervals.
    If I did extend oil change, I would still change oil filter at shorter interval.
    WizeWeelz and blairandgretchen Thank this.
  5. blairandgretchen
    13,942
    76,647
    Dec 9, 2011
    South west Missouri
    I do - for above reasons. $12 for a test kit every 10,000 miles.
    I change oil out at 20-30k, rarely lasts to 40k before base drops/acid rises.
    WizeWeelz and xsetra Thank this.
  6. Ridgeline
    22,726
    123,411
    THIS!!
  7. blairandgretchen
    13,942
    76,647
    Dec 9, 2011
    South west Missouri
    There’s the KR legends that spout 500,000 mile oil, but I say there’s a midpoint between savvy and stupidity.
    S60 - $15k overhaul, $300 oil change.
    100 oil changes on 1,000,000 miles - at 10,000 intervals. $30,000 in oil.
    33 oil changes - $10,000 in oil changes at 30 k intervals.
    Over 7 years - a 20,000 savings $2,850/year is notable, but my bottom line reason is -
    “Fuel dilution/soot/silicon(dirt) is abnormal - rectify and resample”
    Any of the above can wipe out a motor in short order. The average “Every 10k, never sample “ driver, will fall victim to this at some stage.
    Many operators are adept at spotting problems and rectifying before damage is caused. I’m not that smart. So $12 every 10k miles is VERY cheap insurance.
    INSURANCE.
    Not all insurance appears as a policy.
    WizeWeelz, MTN Boomer and xsetra Thank this.
  8. gimacen
    gimacen Bobtail Member
    44
    38
    Mar 25, 2018
    Sad to say, have no clue where to look to start replicating your standards.
    Not tech savvy but gimme 3 tries..
  9. CAPTransport
    CAPTransport Light Load Member
    100
    201
    May 7, 2021
    Fayetteville, NC
    An oil analysis gives you vital information on what is being slushed around inside your engine. It's not a "I don't have to change my oil until this test says things are bad" analysis. That kind of mentality will turn skipping on $400 maintenance into $20K engine rebuilds real quick.
    Speed_Drums Thanks this.
  10. gimacen
    44
    38
    Mar 25, 2018
    Oh yeah that's understood, the PM (OIL FILTERS GREASE+++) would happen ontime everytime but it's sad i wouldn't know where to look to start the good habit of testing often
