Oil Leaking back into cab
Discussion in 'Western Star Forum' started by camel68, Jul 29, 2020.
  1. camel68
    camel68 Bobtail Member
    Have a 2007 4900 with a Detroit series 60 engine. Had oil start leaking out of dash in middle of it around the ECM and there is no oil lines running into cab. It quit after a while and didn't leak anymore.
  3. supersnackbar
    20,091
    52,547
    Aug 19, 2007
    Your Town, USA
    I had a Series 60 years ago that had a factory mechanical oil pressure gauge. For the computer it uses a sensor.
    Cetane+ Thanks this.
  4. 201
    201 Road Train Member
    12,773
    26,283
    Apr 16, 2014
    high plains colorado
    Got oil in your air system? It blows out from the brake valves behind the dash.
    Goodysnap and Cetane+ Thank this.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    2 things I would check. See what kind of oil gauge you have. Maybe it's a mechanical gauge if so that's probably why.
    Check the air tanks and see if u are pushing oil.
