Oil temperature too high
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chopov78, Apr 10, 2016.
  1. chopov78
    chopov78 Light Load Member
    122
    9
    Feb 27, 2010
    illinois
    Cummins isx 2007.Driving on i77 south in Va and on the hills few time dashboard showed me Oil temp too high.I was pulling 41000pound load,but never happend before.
    Any help?the engine dib not shut down and on flat ground runs great.
  3. sawmill
    sawmill Road Train Member
    3,943
    72,280
    May 29, 2015
    Evanston, WY
    What about water temp? I would think if the oil temp is high the water would go up too
  4. chopov78
    122
    9
    Feb 27, 2010
    illinois
    the water was 210f with engine fan on.
    it is ok for the hills and 41000 load.
  5. sawmill
    3,943
    72,280
    May 29, 2015
    Evanston, WY
    I dunno. Hard to say if all you got was a light saying it was high. No temp gauge for oil?
    blairandgretchen Thanks this.
  6. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    My N14 runs 220 EOT with water @ 185 consistently.
    BoxCarKidd and Big_D409 Thank this.
  7. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    Sounds like your oil cooler is failing. The Oil Cooler itself is only about $200 but you have to tear down the entire passenger side of the engine to get to it. 10 to 12 hours labor.
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Don't isx have a oil thermo stat??
    Oil coolers just don't stop cooling.
    But a thermostat will stop the flow if not working correctly.
    BoxCarKidd Thanks this.
  9. MUNY
    MUNY Bobtail Member
    6
    Mar 24, 2016
    Thermostat or Water pump......
  10. MUNY
    MUNY Bobtail Member
    6
    Mar 24, 2016
    but first check the oil temp-sensor ..
  11. NoCoCraig
    2,604
    1,695
    Nov 7, 2010
    Actually, it sounds exactly like the oil cooler. It has not stopped working but it cannot handle a heavy load. Exactly what happened to my 09 ISX. Oil temp would spike up a steep grade then immediately recover, I could usually manage it by keeping the rpm's up. I am not a mechanic so I could be completely wrong. Just going on past experience. If it was the oil temp sensor I would think he would have a constant fault. Based on what the OP says is happening it sounds like exactly what we had happen.
