On-guard system disable question.
Discussion in 'Ask An Owner Operator' started by OTR48+C, May 18, 2018.
  1. OTR48+C
    OTR48+C Bobtail Member
    45
    10
    Dec 13, 2010
    I have a 2016 KW T680 that came with on guard system what is giving me a lot of trouble, this junk is off guaranty and every time that I take it to the KW dealer is a money pit, problem is that get the engine light on every so often and they need to re-adjust the radar of the on guard system, they willing to disable on guard but they told me they have to disable ABS and TC as well what I don't willing to do.
    Is anyone know if this is true that On guard is tie to ABS and TC?
    any suggestion will be appreciate.....
  3. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    Is it the one with the little rectangle box on the dash?
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Partially true. Radar is tied to ABC and TC but GOOD mechanic can reprogram computer to disable
  5. OTR48+C
    45
    10
    Dec 13, 2010
    No, this one does not have that rectangle.
  6. Dave_in_AZ
    427,570
    What happens if you just smash the sensor with a hammer?
    Rollr4872 Thanks this.
  7. supersnackbar
    20,174
    53,192
    Aug 19, 2007
    Your Town, USA
    You lose cruise control and have to hear the annoying tone from the system telling you the antenna is blocked.
    Dave_in_AZ Thanks this.
  8. tallmon
    tallmon Medium Load Member
    657
    321
    Oct 22, 2014
    Unplug the system unit. It is a rectangular box somewhere inside the dash or above the windshield.
  9. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    You instantly become a less safe driver and your fuel mileage drops.
  10. Ridgeline
    22,749
    123,895
    The dealer should have told you that you can disable it through their software because you are the owner, I would have that done.
    win-some-loose-less Thanks this.
  11. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    This^ I wouldn’t buy one with that junk on it but since you did, a dealer should be able to reprogram it.. better get it done sooner rather than later, eventually our gooberment will pass it as mandatory on vehicles manufactured after XX date.. it’s coming.
