Oranges ruined from frozen temp?
Discussion in 'Refrigerated Trucking Forum' started by Jdm5jdm5, Feb 9, 2022.
  1. Jdm5jdm5
    Jdm5jdm5 Light Load Member
    193
    60
    Apr 13, 2016
    I picked up a load of sunkist oranges and set the reefer to 38 degrees and parked and went to sleep. When I woke up the temperature was 22.
    Either the reefer was faulty (the guy I drive for's equipment isn't the greatest) or someone sabotaged me over night.
    The oranges were at a frozen temperature overnight, and I immediately turned it back to 38. Do you think the oranges are damaged or ruined in anyway from an over night at 22
    Boondock Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,995
    185,902
    Aug 28, 2011
    Henderson, NV & Orient
    Don't say anything at the receiver; you might luck out.
    RefMata, Boondock and Jdm5jdm5 Thank this.
  4. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    Depends how they temp out internally at your consignee. And what they look like. I imagine they will check.
  5. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    Since the reefer was at 22 for only a few hours, you might luck out and everything is OK.
    But, I'm of the same opinion as the others, don't say anything. Like Schultz from Hogan's Heroes used to say: "I know nothing!"
    Boondock, Mototom, okiedokie and 2 others Thank this.
  6. wichris
    wichris Road Train Member
    4,522
    9,327
    Jan 17, 2011
    They don't even need to pulp it. Just pick one up, if it's soft it's been frozen and thawed. There will be space at the top of the boxes where they have settled.
    MOBee, Siinman, JoeyJunk and 2 others Thank this.
  7. bad-luck
    bad-luck Road Train Member
    3,453
    6,369
    Nov 16, 2013
    Baltimore, Maryland
    Quite possible, they may notice deterioration during inspection, but Don't volunteer anything. If they want s download on your reefer, your going to have a problem. Good luck.
  8. Trucker61016
    Trucker61016 Road Train Member
    1,617
    4,657
    Sep 18, 2017
    Linville, Va
    Just tell em you were craving some Orange Sunkist Popsicles....because their juice probably frozen inside
    goga Thanks this.
  9. buzzarddriver
    3,857
    11,715
    Feb 1, 2011
    Dallas, TX
    AND if the load has a temp tale, they will see the temp drop and reject.
    RefMata, JoeyJunk, Boondock and 2 others Thank this.
  10. Psyched
    Psyched Light Load Member
    122
    80
    Feb 22, 2013
    Us
    Most likely they didnt freeze if it was only a few hours and it would take a more time than that for the whole load to freeze. More than likely the only damage will be near the end of the shute.
    Most sheds put temptales on the loads now - so depends on the placement of the temptale.
    Really depends on how sharp the receiver is…​
    Trucker61016 Thanks this.
  11. JoeyJunk
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
