Outside air temperature gauge....any suggestions?
Discussion in 'Experienced Truckers' Advice' started by Crazy Alex, Nov 12, 2014.
  1. Crazy Alex
    Crazy Alex Light Load Member
    161
    46
    Dec 1, 2012
    Here n there
    I got 2002 Volvo 770
    I need an outside temperature gauge for the winter
    Any suggestions?
  3. snowwy
    snowwy Road Train Member
    20,635
    13,358
    Jul 6, 2009
    they sell them at all the truckstops. about $20 i think is the price. you just gotta figure out where to mount the sensor on the outside.
    they suck on battery life though, when you use the light to read the screen at night though. they go forever without using the light. you can plan on changing the battery once a month if you use the light.
    i use a zip tie to mount the sensor to the mirror. run wire through the door jam. and zip tie to visor on windshield.
    double yellow Thanks this.
  4. double yellow
    5,945
    10,066
    Aug 28, 2011
    State of Jefferson
    One of the "Xgauges" for my scangauge was ambient air temp. Reads about 5* high when the engine is running though...
    blairandgretchen Thanks this.
  5. blairandgretchen
    14,033
    77,517
    Dec 9, 2011
    South west Missouri
    Cheap road king or generic truck stop brand works fine. Careful where you place the sensor - away from engine heat draft spots.
    Also check garden supply places - greenhouse - or even a HVAC buddy if you have one.
    Very handy. Wet? 30 degrees? Mmmmmmmm. Slow down.
  6. mclass555
    mclass555 Light Load Member
    184
    88
    Jun 5, 2013
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,573
    Jul 15, 2006
    El Chuco, Tejas
    I guess Volvo didn't make that standard until 2003. Been in every 780 I've driven
  8. Bakerman
    Bakerman Road Train Member
    4,663
    8,813
    Jan 27, 2013
    Phoenix, AZ
    I have an '01 Volvo and I have my outside temp gauge mounted next to my cb on the dash. Sensor goes into the dash and follows the coax to the door, jam and mirror bracket. Sensor is then zip tied to inside of passenger mirror.
  9. Tall Mike
    Tall Mike Road Train Member
    8,193
    42,126
    Aug 20, 2014
    New York State
    So basically all brands are pretty much the same ??
    My T660 K-whopper has one but I really need one on my pickup for winter driving here in the soon to be great white northeast..
  10. snowwy
    20,635
    13,358
    Jul 6, 2009
    i like the freightliners. they go DING DING DING everytime it reads 34. CAUTION, ROADS MAY BE ICY.
    it's not accurate in the first place, i certainly don't need to be DINGED everytime it says 35 then 34 degrees. specially without one drop of wet on the road.
  11. PackRatTDI
    14,765
    22,573
    Jul 15, 2006
    El Chuco, Tejas
    Volvo's does that too.
