Overheating in NW Mountains
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by csmith1281, Feb 26, 2021.
  1. csmith1281
    csmith1281 Medium Load Member
    446
    266
    May 29, 2017
    Atlanta, GA
    My truck has started overheating in the hills. I have only ever noticed it happening in the Pacific Northwest, where I haven’t driven really until this winter, so I’m hoping that the brutal climbs there are just too much. But I haven’t noticed many other trucks sitting on the side of the road. Once I get off the hill, my temps come down quickly. I’m not using coolant. I’m driving a 2016 Peterbilt 587 with an MX-13. Fleet spec truck I bought from Prime. I’ve never really had a problem with any hills in the east, but I haven’t been over there recently to compare my truck’s current performance. Could there be something wrong with my cooling system if it can’t handle the hills like that?
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Until you figure out what's wrong try pulling the hills a couple of gears lower than usual. Let that engine run free and easy and it might not heat at all.
    Puppage, csmith1281 and black_dog106 Thank this.
  4. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    I should probably mention that I have had a squealing belt for a while now. Yeah I know I’m douche bag and a rookie and I shouldn’t own a truck. I should roll my truck off a cliff and give all my money to a real trucker and go flip burgers. Thanks. Got that part.
    Could a loose belt reduce cooling system performance?
    25(2)+2 and Flat Earth Trucker Thank this.
  5. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    Problem is, these hills are so steep and so long I have to go all the way down to fourth gear before she can handle them.
    I read in another post about how keeping the RPM range high is good to keep air in the turbo and the fan spinning. But even in the lowest gears, the engine is getting bogged down.
    Do you guys know these hills? California mount Shasta area, I 5, North into Portland, north into Tacoma, east over to Reno, etc?
    Flat Earth Trucker and D.Tibbitt Thank this.
  6. D.Tibbitt
    157,161
    Well the hills out west are alot longer pulls than out east... i always turn on the engine fan when pulling a hill... what are your temps ?...
    Brettj3876 and csmith1281 Thank this.
  7. D.Tibbitt
    157,161
    How many speeds is ur transmission? If u said its a former prime truck then its not really geared for mountains like most fleet trucks.. I have a 13 speed and on the hills u mentioned i am down in 6th gear when loaded to 80k about 20-25 mph... keep the rpms at 1500 or higher when pulling
  8. DUNE-T
    DUNE-T Road Train Member
    7,047
    17,162
    May 10, 2015
    Detroit, MI
    How many miles on the truck? Might just need the radiator washed out
  9. AModelCat
    164,792
    Definitely make sure all the coolers up front are clear. If air can't flow through, they can't cool.
    magoo68, D.Tibbitt and csmith1281 Thank this.
  10. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    last time i was out west my truck ran hot in the hills to but here in Pa its fine
    csmith1281 Thanks this.
  11. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    The engine shuts down at 240°. I’m trying not to let it get that hot before I shut down. I don’t have a manual fan switch.
