Overweight on Drives
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Friedchicken667, Apr 3, 2025.
  1. Friedchicken667
    Friedchicken667 Light Load Member
    64
    126
    May 13, 2023
    IMG_3959.jpeg IMG_4041.jpeg Hey all, new to hauling non-dry van loads and my last couple have been overweight on the drives. I had a 48’ hopper and a 45’ 7000 gal tanker both fixed axles at rear of trailer. Now the hopper was 81k on gross (had to get a permit) and 36k on drives. The tanker was 79,500 gross with 35,400 on drives. I moved my fifth wheel forward as far as I could and I was still at 34,800 (half tank of fuel to boot) with about 12,900 on steers.
    I’ve never had weight issues before but the only thing I can think of is I recently put on a headache rack with chains and binders, surely adding about a thousand pounds. Do I just need to stipulate hauling maybe a max of 42k loads? I’m stumped here
  3. Dave1837
    Dave1837 Road Train Member
    1,403
    4,355
    Nov 16, 2019
    Pennsylvania
    The rack, chains and binders certainly aren't helping but I don't think that's your issue. What was the weight on the trailer axles? With liquid you're typically always going to be heavy somewhere, I was always heavy on my trailer a few hundred pounds. May need a 48 footer. Dry bulk you'll probably have to load from the rear hole if it's a 3 compartment, 3rd hole if it's a 4.
  4. Friedchicken667
    64
    126
    May 13, 2023
    Weight on trailer axles for the tanker was 31,900 on this last load. I appreciate the advice on the tanker and hopper loading, but I’m leased on with a company that does power only loads, never know what I’m walking into. Full disclosure: I was guessing on the tanker length, didn’t actually measure. All I know is it was 7000 gal only filled with about 4300 gal. No baffles, pushing me back and forth like crazy back there.
  5. mitrucker
    mitrucker Road Train Member
    5,553
    10,547
    Dec 15, 2010
    Lapeer, MI
    Tanker is 43’. Your problem is your fifth wheel. Trucks that pull tankers exclusively use taller risers on the fifth wheel which is supposed to distribute the weight more evenly.
    Hammer166, Sons Hero, Dave1837 and 6 others Thank this.
  6. Diesel Dave
    10,069
    35,708
    Jan 20, 2010
    Hesperia, Ca.
    You beat me to it.
  7. Friedchicken667
    64
    126
    May 13, 2023
    ####. Didn’t know about that but makes perfect sense. Sitting at a pilot in Midland, TX and looking around at all the tankers and I see a bunch right off hand.
    The only thing I know about trucking is how little I know about trucking, lol. Thanks guys
  8. Kyle G.
    Kyle G. Road Train Member
    3,914
    20,654
    Jan 23, 2016
    Eastern Iowa
    Unrelated, but you may want to do something to secure the bottom hooks on those ratchet binders. They will unscrew over time as you drive down the road.
  9. 201
    201 Road Train Member
    13,003
    26,831
    Apr 16, 2014
    high plains colorado
    Aren't insulated thermos bottles like that, typically heavy empty weight? Don't recall too many tankers with rear sliders. Why is that?
  10. kemosabi49
    11,118
    48,815
    Jan 13, 2013
    SW Arkansas
    When I approach a scale, I try to get the product in the trailer really rocking. Most of the scales don't want to wait for your product to settle down and will green light you. Except Virginia. I always had to sit there until they could get an accurate reading.
    As long as I'm not over gross by very much I don't worry about axle weights.
  11. Diesel Dave
    10,069
    35,708
    Jan 20, 2010
    Hesperia, Ca.
    I did that with Natural Gas and Butane, no baffle thermo bottles.
