Peterbilt 379 no cab power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dairy22, Apr 3, 2026.
  1. Dairy22
    Dairy22 Bobtail Member
    4
    4
    Apr 3, 2026
    Hi guys I’ve got an 01 379 with a c15 I just replaced 70 pin harness and battery cables and have no power to cab. I’ve got power at starter relay/fuses and ecm fuse but nothing in cab. I checked frame rail breaker and nothing there either just wondering what else I could check? A couple years ago it started eating starters so I ran a new wire from ignition to solenoid and everything was fine. Replaced harness and cables and got nothing now. Thanks
  3. Big Road Skateboard
    7,362
    41,931
    May 2, 2021
    Do those years still have the 2 ignition relays on the left side behind the cubby hole on the dash?
    @wore out? I dont know who here has a later model 379.
    cke and blairandgretchen Thank this.
  4. Dairy22
    4
    4
    Apr 3, 2026
    I seen a 75 amp relay basically right behind steering wheel with 2 big wires hooked to it didn’t have any power there
    Big Road Skateboard Thanks this.
  5. Big Road Skateboard
    7,362
    41,931
    May 2, 2021
    2 big wires and 2 small?
  6. Dairy22
    4
    4
    Apr 3, 2026
    Maybe there were 2 smaller on back side I’ll have to look again in am. The 2 big wires were on the front side toward dash
  7. Big Road Skateboard
    7,362
    41,931
    May 2, 2021
    I honestly haven't worked on one of these later dash style 379's, FYI. I'm going off what I've seen in the older ones.
    Either way, no power to either side of that relay? If not, Just for S&G, check for any broken mid sized pisitive cables at the alternator, starter, and in the battery box.
  8. blairandgretchen
    14,028
    77,431
    Dec 9, 2011
    South west Missouri
    Need a Peterbilt 98 379 wiring diagram
    Try Supermiller for other schematics. I have a few.
    The relay behind the ‘A’ panel (Marlboro cubby) is the accessory power relay.
    Why am I thinking there’s a power wire dropped down behind your batteries or battery box that got left off? If you replaced all the battery cables.
    cke, Big Road Skateboard and wore out Thank this.
  9. Texasgordo
    Texasgordo Medium Load Member
    465
    1,885
    Sep 11, 2007
    Gonzales, Texas
    I had no power for anything Thursday morning but it was a broken end on my ground cable for the starter. It was the thick cable from the battery box to the starter. I had to use jumper cables to get it starter.
    This was on a 04 Peterbilt 379 with a CAT. I'm not saying that is your issue but it's what happened to me.
    blairandgretchen Thanks this.
  10. wore out
    wore out Numbered Classic
    17,693
    221,857
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If you had power messed with it then no power go back where you messed with it.
    cke and Big Road Skateboard Thank this.
  11. Big Road Skateboard
    7,362
    41,931
    May 2, 2021
    Hell, how did I miss the part about having replaced the battery cables?
    cke, Texasgordo and wore out Thank this.
