Poor fuse connections
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 17, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    I’ve got a couple fuses in my ‘87 Pete, that are loose. Replaced all the fuses but 2 or 3 of the sockets are a bit loose. I tweeked them with a tiny flat screwdriver and it helped 2 of them but the other socket is still trouble. Thought about dropping a tiny bit of solder on the spades of the fuse and file it down some. Do y’all have any other methods?
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,932
    76,570
    Dec 9, 2011
    South west Missouri
    Was thinking of some origami with some aluminum foil to wedge in with the spades - seem to have seen that trick somewhere.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    is it the pins or the connector that is the issue.
    Pins can be replaced and tweaked easily once removed.
    If its the connector, replace if possible, if not plastic shims can be made from scrap plastic and super glued into place to keep the pin from moving.
  5. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    You can also tweak the legs a little. Gently bend in opposing directions.
  6. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
