problem with reefer unit need help
Discussion in 'Refrigerated Trucking Forum' started by surfer24, Apr 17, 2014.
  1. Hyleygrove
    Hyleygrove Bobtail Member
    26
    4
    Nov 2, 2022
    Coolant temp is this a sensor you’re referring to how do I check coolant temp ?
  3. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    It's a brass sensor that is threaded into the head.Scroll through unit data until is says engine temperature.It should be reading around 160 f depending on the ambient outside temp of your location.
  4. Hyleygrove
    26
    4
    Nov 2, 2022
  5. Hyleygrove
    26
    4
    Nov 2, 2022
    Ok thanks a lot
    reeferwrencher Thanks this.
  6. Arte2508
    Arte2508 Bobtail Member
    Washington
    Mine reads in the 130s with low 30 degree Temps outside. Sound normal? Having same issue. New battery voltage reads fine not shutting off on auto mode when reaching temp. Just started doing it out of nowhere.
  7. reeferwrencher
    613
    1,577
    Aug 4, 2018
    Sounds too low,I would replace it.
  8. rogueunh
    rogueunh Road Train Member
    1,086
    23,065
    Jan 4, 2011
    I had a unit doing this, and it was no the coolant sensor. Instead the thermostat was stuck open, so it wasn't allowing the engine to reach a high enough operating temp.
