Pull up steering techniques-help!
Discussion in 'Questions From New Drivers' started by Bummwear, Nov 1, 2018.
  1. Bummwear
    Bummwear Bobtail Member
    Hey everyone! So I found one of my major weaknesses, straightening the tractor trailer out in the lines of the cones. I'll try to explain this the best way that I can.
    Let's use the straight line backing setup as an example to make it easier. So if I drift way too much on the right to the point I need to pull up, I go forward. Ok the problem for me is this, as I'm pulling forward, I see all my cones in the right mirror and none on my left (trailer covering all the cones.) So my question is this, to see my cones in my left mirror, how much do I turn my wheel, how long and which way? Do I start the turn before I pull up or as I'm pulling up?
    Anything helps! Thanks!
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    First off, I suspect you’re “steering to much”, going both backward and in the pull-up. Cut your wheel correction about in half and see what happens.
    And you need to be moving slowly, at the same time you’re make slow corrections in your overall rig configuration (“atttitude”) Don’t turn hard while stopped, then move. Don’t overthink the situation.
  4. CK73
    CK73 Medium Load Member
    461
    602
    Dec 19, 2017
    It takes a lot of space to get the rear end of the trailer where it needs to be if you are way out of line. Best to start over in close quarters as opposed to trying to correct from a bad setup.
    Focus on the putting the ### end of the trailer where it needs to be, always.. The mirrors are only a tool and can be deceiving. Until you are experienced enough to "see" all of the trailer with your mind's eye, GOAL all day long and compare where you think the combo is in your mind vs reality, until the two come into sync. It may take months for the mind to visualize what cannot be seen due to HUGE blind spots. Always focus on the rear end of the trailer and where it needs to be, and how to get it there. Trailer is the boss, not the tractor.
    Bummwear Thanks this.
  5. b61mack
    b61mack Light Load Member
    60
    70
    May 18, 2010
    port murray nj
    Check out you tube...they will have videos
    CJ701 and Bummwear Thank this.
  6. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Also, learn to see improper or unwanted drift early, and immediately initiate a minor, gradual counter-correction. You may or may not need to initiate a pull up. Just depends on the situation. Some pull-ups are required, some not. Experience will help in this regard, but if in doubt, do a minor pull-up correction to try and get back on the right track.
    CJ701, Bummwear, CK73 and 1 other person Thank this.
  7. gentleroger
    gentleroger Road Train Member
    7,856
    21,458
    Jun 1, 2010
    This 1,000,000 times.
    A little pull up early avoids several pull ups later.
    Lepton1 and Bummwear Thank this.
  8. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,710
    May 10, 2015
    Fort Myers, Florida
    The purpose of a pull-up is to point the trailer in the right direction. So when you pull up, watch your Mirrors On Your Side, and when the trailer is pointed the right way start backing up and crowd that cone on the left.
    Somebody else said it, but it Bears repeating, make small adjustments on the Wheel.
    The principal is the same for straight or angled backing. Practice, practice, practice.
    Bummwear and gentleroger Thank this.
  9. Clawbytes
    Clawbytes Bobtail Member
    12
    Nov 1, 2018
    One of the first advice I was given was to "steer towards your problem".
    So if you're jacked to the right, simply steer to the right.
    Another advice would be to buy a small toy truck. It helps a lot with your visualization.
    Edit: I was talking about backing.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    One thing you need to learn about learning to drive. Get out and look frequently! Companies love drivers whom get out of the cab and look to see what or where your trying to park. The other headache is two fold. The class your taking has the cones moved in a foot from the actual test so it will be easy for you when you get there. The other headache is about trailers themselves. Trailers are only aligned for pulling them forward. Yet whe you back up they go where ever they want.
    Keep practicing. It does get easier. A little steering wheel movement is better than alot.
  11. Steviej
    Steviej Bobtail Member
    6
    Nov 3, 2018
    This is ABSOLUTELY CORRECT!!
    I’m recently graduated with no experience, but steering toward the problem is right on the money. I’ve seen it live and in person. Also, small corrections on the wheel is also very true. The Sysco driver I spoke with for months before I went to school told me - small corrections. He was dead on.
