Question about trailer lights
Discussion in 'Freightliner Forum' started by Dorman1986, Mar 26, 2022.
  1. Dorman1986
    Dorman1986 Bobtail Member
    So, I drive a 2022 Cascadia, and recently my truck decided it didn't want to turn on all the lights on the trailer. I'm no mechanic so I don't even know where to begin trying to figure out the problem, but I thought, maybe it's a fuse. I stopped before yanking a ton of fuses I didn't really understand and tried another solution. I pulled the pig tail from the trailer and didn't see any obvious damage there, then repeated on the truck side of the electrical... Eventually not finding anything obvious I just gave up and moved on. For whatever reason though when I turned my truck back on and started to pull away from the dock, everything was working....
    Is this just a situation of life trying to screw with me, or did I accidently fix something?
    TLDR: The side lights and inner taillights were not coming on when turning on my lights. what gives?
  3. pavrom
    pavrom Road Train Member
    3,221
    7,436
    Apr 29, 2012
    NE illinois
    ...you accidentally became mechanic ..
    stwik and Kyle G. Thank this.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Sometimes you have to wiggle the plug just right to get good contact on the electric connectors. They get loose or get dirty
  5. supersnackbar
    20,179
    53,221
    Aug 19, 2007
    Your Town, USA
    If the pins in the trailers pigtail socket have a slot down the middle, take a thin bladed screw driver or a blade from a razor knife and slide it in the slot of the pins and gently spread them just a little. Don't get too agressive, they break if you try to spread too much.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    You might not have fuses that pop and die. Instead you may have breakers that trip when needed and reset and reactivate after the ground or resistance has been reduced.
    If the breaker is tripping because an exposed wire was occasionally grounding out it will go out for a while until it's stops grounding and the light will return. You should definitely inform your employer of the issue and have them get it looked at.
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,367
    Mar 5, 2012
    Omaha, NE
    Buy some electrical contact cleaner, a 7 way wire brush made by Grote and clean your connectors and reapply dielectric grease.
    Connections do get corroded and make bad connections.
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    I carry a little “control driver” screwdriver to spread the pins in the trailer socket a bit. That usually cures the kind of woes you describe. When you open the weather cover on a trailer socket look in there and you’ll see the part line in the 2 pieces of the pins. Be careful when you spread the pins, if you break one side of the pin off you just made your problem worse.
    Rideandrepair Thanks this.
  9. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    YES, Spreading The Pins A Wee Bit Helps Tremendously!!
    There USED TO BE An Electrical Spray Available At T/A,....still is?
    It WORKED WELL To Dissolve Accumulated Electrical Goo In Pigtails (Dirt, Dust, Other).
    Don't Recall The Name But It Was In Repair Shop Building/Office,
    >>Or Just Get Electrical Contact Cleaner<<.
  10. Rideandrepair
    17,575
    56,939
    Aug 8, 2015
    An old Company Drivers trick is to unplug the pigtai from the Truck. Inspect for corrosion. Dip each end into the fuel tank. Plug it back in. Another problem that’s common, is the Trailer socket gets worn, especially if it’s plastic. A piece of cardboard, preferably a thin piece of plastic ( lasts longer) wedged between the pigtail and socket, on the top, as you plug it in, so it fits tight sometimes works.
    ProfessionalNoticer Thanks this.
  11. Tb0n3
    Tb0n3 Road Train Member
    4,742
    9,661
    Oct 5, 2012
    Earth
    Good idea. Make those fuel filters do their job.
    Really, if the contacts are corroded there's something called Contact Cleaner that is used to clean parts.
