Question, can I just take a nap break anytime ?
Discussion in 'Questions From New Drivers' started by Rob91x, Feb 3, 2022.
  1. Rob91x
    Rob91x Bobtail Member
    25
    17
    Feb 2, 2022
    Can I just take a nap break anytime I want if I'm tired ?
  3. Malt Ball Cult
    Malt Ball Cult Light Load Member
    151
    444
    Jul 24, 2021
    It's best to wait until parked.
    MysticHZ, jsnell, TripleSix and 19 others Thank this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,996
    19,063
    Nov 1, 2010
    Burnsville, MN
    The choice is yours.
    You do have free will.
    But if you decide to take a nap and end up late, there may be consequences.
    Probably best to plan your time well enough so you don't need a nap?
    The_vett, bryan21384 and D.Tibbitt Thank this.
  5. Espressolane
    18,752
    117,663
    If your tired, you most definitely should park and take a nap, then get outside the truck for a few minutes and move around. You can take a nap at any time you want. You have 14 hours and a required 30 minute break.
  6. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    :D
  7. D.Tibbitt
    157,331
    yes you can nap at anytime. but it may effect your electronic logs in a negative way.
    The_vett and God prefers Diesels Thank this.
  8. Malt Ball Cult
    151
    444
    Jul 24, 2021
    Depending on what type of loads you're running, your lanes, etc, it's sometimes necessary to nap.
    I've found that I can fit a nice 15 to 20 minute nap into a 30 minute break.
    If you need more sleep than that, as is sometimes the case, I suggest you learn about the Split Sleeper Berth Provision, but, do NOT mess with it until you fully understand how it works, and make sure that your company's policy, and ELD, are set up for it, should you decide to use it.
    Mattflat362, The_vett and Bean Jr. Thank this.
  9. meechyaboy
    meechyaboy Heavy Load Member
    796
    1,227
    Oct 4, 2018
    Detroit, Michigan
    Tripplanning!!!!! You have time for whatever you plan for.
    The_vett Thanks this.
  10. Sirscrapntruckalot
    Today's life lesson..
    I say include a nap in your trip plan. Hell, include 2 or 3, you might want a challenge.
    Sirscrapntruckalot -
  11. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    Yes I usually have to stop every Monday and nap. Coming off a weekend getting back into the night shift routine is tough. I give myself an extra 2 hours on my trip, good nap and I don't lose any time. Problem with naps is, they become addicting and you'll want to take one every day
    homeskillet, Malt Ball Cult and lester Thank this.
