Question: Fees to Alaska?
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Feb 26, 2023.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    I can not to Canada currently. I am thinking on working on that for the sake of taking loads to AK.
    Loads leaving Me to Alaska is paying 14 to 16k
    Leaving NC to Ak is paying 20 to 23k
    Leaving AR to AK. Is paying 12 yo 14 ish k.
    This prices are before Landstars 35 percent. Most of these loads where hazmat weighing in under 32, 000.
    For drivers that go to AK. If I haul a 20,000$ load to Ak. Landstar will get 7k. Leaving 13 on the bone. What other fees are there? Ferry, Customs, anything? Also can I switch from USA hours to Canada hours and then drive for the 16 hours?
    blairandgretchen Thanks this.
  3. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    You will have to get permits for the Yukon and state of Alaska. Repair shops are few and far between and fuel is expensive. What about the return? Are you prepared to deadhead back?
    I hope it works out for you. I never did it in a truck but drove up from Washington state to Fairbanks in a car and it is a beautiful drive.
  4. Albertaflatbed
    Albertaflatbed Medium Load Member
    413
    1,240
    Nov 20, 2022
    Nisku, AB
    When you enter Canada you are required to run under Canada Federal hours of service regulations.
    13 hours driving, 14 hours on duty within a 16 hur window. Once north of the 60th parallel you can switch to the north of 60 rules.
    I recommend you call the provinces transportation departments that you will be traveling through to find out the permits required and costs. For the Yukon you buy your permit at the scale in Watson Lake.
  5. Long FLD
    Long FLD Road Train Member
    12,905
    54,127
    Mar 4, 2015
    Canadian HOS are an option, they aren’t required. All my time running back and forth to Canada I never switched to Canadian rules.
  6. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Noted thank you
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    It is required to follow our HOS rules when here, our rules are just a little more relaxed than yours. I can think of the 34h reset vs ours is 36. You have to be running hard to break our 70 in 7 days when including a reset, rather than your 70 in 8 days. And the 24h off duty after working 14 days in a row. They would park you.
    It may appear to be decent money, until you get there and realize there is zero coming back. Quite a long deadhead to anywhere from there. Post pictures if you make the trip, I'd like to do it someday, whether by truck or by little truck.
  8. kay_ray
    kay_ray Medium Load Member
    492
    1,236
    Jun 6, 2019
    Heres an example .
    Little rock ,ar to anchorage ak -4000 miles
    Gota deal with winter storms, single lane highway 1 ,closed roads, expensive fuel barely any mechanic shops .
    Total paid $14,000.Gross after landstar take their cut $9,100 thats wooping $2.27/ mile not counting the 1000 to 2000 mile dead head
    You can do better here in 48 states even in this bad market.
    Magoo1968, Cat sdp, loudtom and 3 others Thank this.
  9. blairandgretchen
    13,950
    76,707
    Dec 9, 2011
    South west Missouri
    I just did the same math -
    Charlotte, NC to Anchorage,AK - then bounce empty to Seattle - 4,328 miles loaded - $13,000 - $3/mile loaded - then 2261 miles to Seattle for a total of 6,589 miles - $1.98/mile.
    SL3406, cke, Cat sdp and 2 others Thank this.
  10. Long FLD
    12,905
    54,127
    Mar 4, 2015
    You are required to be in compliance, you aren’t required to switch your log to run Canadian HOS. I should’ve worded my reply better. I never switched mine even if I was up there for a couple days because then I knew I was legal when I crossed back into the states.
    stwik, cke, Siinman and 3 others Thank this.
  11. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Thats every thing I needed to know. Thank you every one.
