Question for Heartland Express Drivers
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by rgreider, Mar 17, 2025.
  1. rgreider
    rgreider Bobtail Member
    28
    32
    Apr 10, 2015
    El Dorado, AR
    I am purchasing a 2022 Freightliner Cascade from Stoops in Indianapolis. They said the truck came from a fleet of Heartland Express trucks. It has 304K miles.
    My mechanic is going over later this week to take a look at the truck, maybe take an oil sample. My question for drivers is…How often were you required to do oil changes/PMs? How many miles? Were you able to confirm they were in fact “changing” the oil or merely “adding” oil.
    Trying to get a sense of the care this company takes with their truck maintenance, as they typically do 3 yr/350K miles then dump them.
    Any info would be extremely helpful.
    Thanks
    Lonesome and singlescrewshaker Thank this.
  3. Rugerfan
    Rugerfan Road Train Member
    7,745
    39,684
    May 3, 2011
    Redding,CA
    rgreider and singlescrewshaker Thank this.
  4. Opus
    132,400
    I believe Schneider does theirs at 80k
    Lonesome Thanks this.
  5. rgreider
    28
    32
    Apr 10, 2015
    El Dorado, AR
    OMG, that’s insane. My current small fleet owner has us do them at 25K, but my personal mechanic is recommending 16K. Just wow.
  6. Opus
    132,400
    Just call Heartland and ask them
  7. Suspect Zero
    Suspect Zero Road Train Member
    2,531
    9,736
    Oct 10, 2016
    Brookfield, IL
    Wow. I don't know how you could get 80K out of any oil in a DEF engine. Well, actually any engine.
    Bulkmatic was doing changes at 60K because that's what manufacturer recommended, but after 46K it would start burning oil to try and stay alive.
    rgreider Thanks this.
  8. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,916
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    I do mine at 20k, just because its easier to just look at the odometer and be able to know...
  9. silverspur
    silverspur Road Train Member
    1,761
    8,166
    Sep 26, 2012
    Heartland has a history of keeping their trucks in top condition.
    I remember people buying them directly from the company and hauling them off the yard when I worked there 15-20 years ago.
    I saw them do a service/oil change in less than 15 minutes one time. Several mechanics hitting it like a Nascar pit crew right before closing time.
    In that regard, they are the best. The care of the trucks was the key to their success. Very efficient outfit.
    Trucks went through an inspection lane every time they hit the yards M-F 0730-430 and Saturday 8-12. Guy would pop the hood, check air pressure on tires, walk beneath it in the pit looking for issues.
    Rare issues while out on the road were fixed the same day.
    GoLowes48, Knucklehead, ducnut and 5 others Thank this.
  10. blairandgretchen
    13,950
    76,709
    Dec 9, 2011
    South west Missouri
    Though worlds apart, I change oil on my 1995 12.7 Detroit based on oil samples. I added a low micron , one gallon bypass filter to it - send samples in every 10k miles. Generally I change at 30-40k miles, based on oil health. Base number (acidity) is usually the factor, mainly due to low miles on the unit/annually. (50-60k annually).
    Last company truck we drove was a 2015 DDEC 15 - and the spec was 50,000 mile oil changes, as I understand, one of the filters served as a bypass oil filter.
    Without sampling and lab analysis, oil is often thrown out well before it's safe serviceable life.
    I'd drop by Heartland with a box of donuts and have a chat with the service manager and gain some insight.
  11. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    If they run High Capacity Oil Systems you can run longer, Heartland samples the oil between changes, and call so in early. The tractor I drive tractor I drive has over 350K does not burn any between changes, Get an oil change every 60,000 miles.
    Sirscrapntruckalot and rgreider Thank this.
